1999 Mustang GT
13.21@104.5
engine noise
when i go down the drag strip i notice a noise coming from my motor which my old motor used to do also and its hard to describe but the best way i could discribe would be that it sounds like dropping really small rocks on cement. or something like that. anyone know what im talking about? it does it when i am at wot or even if im on the freeway in 5th at 3/4 throttle and i can hear it well then.
![]() iTrader: 1 reviews
exhaust leak? im not too sure, i have somewhat of the same thing but it only happens once and a while, usually when i start my car and the next 5-10 mins after that
uhhmm... anyway ya can record it and on put on the comp? or any other way to describe it... heh, does it do it while it's idling or only at wot? does it get faster when you rev it from idle?
![]() 2004 GT Boosted by Vortech |
1999 Mustang GT
13.21@104.5
no it wasnt an exhaust leak i dont think...although ive got an exhaust leak now too since i put my upr xpipe on which is comeing from the drivers side where the manifold and midpipe meet. another thing that i notice about my motor is like my old motor when it was bad it would make a pitter-pattering bearingish noise when i accelerate normal and slightly hold the rpms in the 2.5k+rpm range but the old motor had to warm up a little before it would do it and this motor does it till its been warming up and driving for about 5 mins or less.
its confusing i know but it really bothers me since im no mechanic and im not really sure how to find out whats wrong. or if there even is anything wrong....all i know is that as soon as i get my udp's installed next weekend im gonna get a dyno tune from blood enterprises. maybe things will be better then. |
#5 | |
1999 Mustang GT
13.21@104.5
#6 | |
Are you sure it's from the motor and not something else?
1999 Mustang GT
13.21@104.5
it really sounds like its from the motor and the oil lvl looks good...ive been checking it often because ive been worried. i let the car warm up or at least 30 sec but i try to make it about a min.
2001 Mustang SVT Cobra
check for any loose parts/bolts under the hood. Could be a vibration from engine. Otherwise, do you hear it more from the bottom, firewall, top???
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
its not detonating is it?
1999 Mustang GT
13.21@104.5
i cant make it make the noice without it being drivin so its hard to tell ill check it out next time i drive it. and i dont really know a lot about detonation so unless someone rode with me i wouldnt know.
#11 | |
1999 Mustang GT
13.21@104.5
it doesnt sound like tinging....i use regular cuz im not tuned for higher and i use chevron and 76 only. also i use injector cleaner every month or so.
Current Mods: -K&N cai -BBK 75mm TB -BBK Plenum -UPR catted x-pipe -A/T Flowmaster cat-back -Diablosport (out of box tune) -FRPP 4.10s -Motive bearings (rearend) -Spec Aluminum Flywheel -Steeda UDP's (Well they will be on next weekend) -Ive got royal purple throughout the car but its made the noises which are more of like ticking noises since before i had half of those mods. |
From Chevron to 76... That's a shocker for that engine.
Some ticking is normal in these cars, sometimes the injectors will make that noise and is more noticeable when you have a wall or something next to you and the sound bounces off. Also, try doing a motor flush. Be careful since you have a 99 and if it's high mileage, flush the engine with less time than recommended. That should help free up some crap/sludge inside. After you do the flush, make sure you use Restore (it really works) to re-coat and lubricate all parts and seals since the flush might dissolve a little too much on an older engine. Now you described "rocks hitting the pavement". Is it more like a rhythm/steady noise or is it a variable ticking noise?
1999 Mustang GT
13.21@104.5
variable ticking noise....and whats wrong with the gas i use? i thought both chevron and 76 were good. also this motor only has about 18k on it my other one had 65k
76 is pretty cheap I would think, Chevron is good, I only use Chervon and Sunoco.
76 is not a good gas, period. I won't get technical, but you can do a search and you will find out. It's like Walmart/Sams fuel. Don't do it.
Does the noise goes away anytime you hit the clutch?
1999 Mustang GT
13.21@104.5
i told you when the noise happens other than that you cannot hear anything.
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
You shouldn't run 87 octane- even on a stock tune. That's all I will say.
#19 | |
One Man Wolf Pack
why I run 87 and my car is fine. and thats what the manual calls for.
![]() ΜΟΛΩΝ ΛΑΒΕ
Achieving more N/A power!
A ticking sound coming from your engine is a good sign of a rod bearing going bad.
How often do you change your oil? Do you do it yourself? Take it to get the oil changed and ask the mechanic to hold a strong magnet to the old oil as it pours out of the bottom of the car as they are draining it, or do it yourself if you change your own oil. If there are metal bits in your oil, it's time for an engine rebuild. Don't drive it anymore! I don't mean to scare you with all this, especially since it's probably your only car and hence your daily driver, but I would go do this immediately.
Brendan '99 Mustang GT [ 318 rwhp N/A ] - SOLD ( )'04 F150 XLT SuperCab
Threads Similar to: engine noise
| Engine Noise? | coltonrobertson | V6 Mustangs | 3 | August 27th, 2007 08:51 PM |
| Engine noise | energiesource | 99-04 | 4 | May 17th, 2007 03:43 PM |
| Engine noise | Juggalo_X | V6 Mustangs | 6 | January 28th, 2007 03:24 PM |
| Help With Engine Noise | AM1AW | 2005 - 2010 | 3 | September 17th, 2006 07:22 PM |
| engine noise 302 please help!!!!!!!!!!!! | brianw3512 | 5.0 Mustangs | 1 | July 28th, 2006 04:42 AM |
