VT, Crower, or COMP
Old July 30th, 2007, 04:44 PM   #1
2002 Chevrolet Impala
TheBusher will become famous soon enoughTheBusher will become famous soon enough
VT, Crower, or COMP
I'm looking at getting a mild set of cams for my 04 GT and was wondering peoples opinions on the better brand (by better I mean most power & reliability). I want the most aggressive cam I can get but I don't want to have to get my car dyno tuned, but I will replace my springs if need be.
Old July 30th, 2007, 05:00 PM   #2
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
crower.
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old July 30th, 2007, 05:09 PM   #3
Nate's4.6 is on a distinguished road
Crower
www.fquick.com/Nates4.6
Old July 30th, 2007, 05:15 PM   #4
So would something like this
http://crower.com/cgi-bin/detail.cgi?prod_id=62811-2
or this
http://crower.com/cgi-bin/detail.cgi?prod_id=62801-2
be to aggressive for stock computer and springs???
Old July 30th, 2007, 05:40 PM   #5
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
+5, Crower.
Old July 30th, 2007, 06:10 PM   #6
or this
Anyone???
Old July 30th, 2007, 07:35 PM   #7
02steedagt is on a distinguished road
Send a message via AIM to 02steedagt
comp 262.... or if you have a diablo or sct tuner, you could probably get away with the 270's, but be careful with that. i know that the 262's can run on the stock tune... and Comp Cams makes a GREAT product.
"America is all about speed. Hot, nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old July 30th, 2007, 07:46 PM   #8
So maybe a 270, but anything less will work? So what is more dangerous about running the 270, no dyno tuning or running stock springs?
Old July 30th, 2007, 08:43 PM   #9
Proud American
MustangMatt96GT's Avatar
I say running stock springs is worse, but the dyno is needed for them too! I personally am really likeing the Crowers, but I will be going with this cam for my top end rebuild!
Cams
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old July 30th, 2007, 08:55 PM   #10
I kinda thought it would be worse on the springs. I want to get a 270 comp or a 62801-2 crower, I will replace the springs, get 3.73s & an SCT tuner (I'm hoping the tuner will suffice until I can afford the dyno tune).
If anybody thinks that the above is a poor choice... as in... it could kill my car... PLEASE let me know before I make the purchase.
Old July 30th, 2007, 08:59 PM   #11
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Do not run comp 270 cams with stock pistons unless you want problems. I have 8 pistons with half moons right now. Comp uses advanced intake timing to make power and you need valve reliefs cut into your pistons to make them work. However, they do make great power.
Old July 30th, 2007, 11:12 PM   #12
zerofx150's Avatar
2003 GT
13.6 @ 101
zerofx150 is on a distinguished road
Send a message via AIM to zerofx150 Send a message via Yahoo to zerofx150
so whats the lift on the stock cams, and if the comp 270s are bad why doesn't comp inform people that they need this?
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports.
Old July 30th, 2007, 11:32 PM   #13
Proud American
If the comp cams are degreed, I dont think you will have problems, but I could be wrong!
And Busher! When you do this if you need some help or just want a second pair of hands I am always wanting to work on these stangs!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old July 31st, 2007, 02:31 AM   #14
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
im running comp 262 cams in mine and have no complaints.
Old July 31st, 2007, 08:39 AM   #15
MM's Mad Scientist
acmillr's Avatar
Slow Fella
The 262's don't have as much advance on the intake timing. If you degree the 270's (retard the timing) to be able to work, you will lose the increased HP these cams produce. Just run them- I didn't listen either, and I found out the hard way. Comp doesn't tell you about this because they would not sell as many cams.
Here is a quote from another source:
"Comp Cams Stage 2 Billet camshafts 99-04
Our Favorite, awesome sounding idle, great power increase, raised redline, computer tuning recommmended for peak performance but not required. 3.55+ gears recommended, Valve springs required, must use notched pistons for valve clearance."
mmr racing
Old July 31st, 2007, 08:40 AM   #16
MM's Mad Scientist
acmillr's Avatar
Slow Fella
I had no complaints either- until I opened my engine. You couldn't even hear the PTV contact noise.
Old July 31st, 2007, 09:42 AM   #17
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
I recommend Comp cams... Dont hold me to this because im not 100% sure, but i've heard some bad things about crower cams. I've heard from quite a few people that they sometimes do sloppy work in the grinding of their cams. Again, this is just what i've heard, but i'd recommend you do some research before choosing. Just a tip.
The XE270AH cams are pretty good cams for a street car though. but they'll requite a tune. The XE262AH might not although...im not sure.
Old July 31st, 2007, 10:06 AM   #18
bluestang96 is on a distinguished road
The comp 270s will work with flat top pistons if degreed properly. The 4* advance that comp cams grinds in is no defect and is there to make the cam more street friendly as it lowers the powerband in the rpm range. If
these cams are not degreed properly you have a good chance of having ptv problems. Take into account that stock cam gears can be almost 10* off from the factory and the grind advance... well you get the idea. But this goes for any aftermarket cam install...degree them. The 262 will probably be your best choice for the street and makes similar power compared to the 270 but in a more useable rpm range for a street car. The car really should be dyno tuned to get your A/F dead on and also get the most out of the cams, if your already 600 dollars in the hole you might as well shell out a little more to get the most out of your cams.
Old July 31st, 2007, 02:06 PM   #19
noob is on a distinguished road
are these 262 cams. http://www.compperformancegroupstore...y_Code=106-CAM
"He that is good for making excuses is seldom good for anything else."
"Who is wise? He that learns from every one.
Who is powerful? He that governs his passions.
Who is rich? He that is content.
Who is that? Nobody."
Old July 31st, 2007, 02:10 PM   #20
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Yes. Buy those and you will have two extra cams.
Seriously, those are for the 4V motor.
Threads Similar to: VT, Crower, or COMP
Crower cams energiesource 99-04 20 August 8th, 2007 11:15 AM
Crower Cams MustangJon255 2005 - 2010 1 July 9th, 2007 08:02 PM
Crower Stage 3 cams Norse1974 2005 - 2010 42 June 30th, 2007 10:54 PM
crower NPI cams Monster stang 97 96-98 24 May 23rd, 2007 06:04 PM
Crower cams or COMP wirenut666 99-04 1 March 8th, 2007 06:37 PM
