window wont rull up and its raining.
Old July 30th, 2007, 05:40 PM   #1
coffinator6's Avatar
03 GT, 92 coupe 2.3T
coffinator6 will become famous soon enough
yesterday my window decided not to roll up. So I removed the door panel and used a 12volt source to bypass the switch and all that stuff. After finding that the switch wasent getting the right amount od power I decided to wait until today to find the reeal problem. After everything was back together the window functioned normally. This morning during some errands it worked fine. Today after getting to work the window was stuck down. I tried bypassing the switch with a piece of wire but no luck. I ended up using some aluminum paper and some masking tape to cover it while raining.
When I try to roll the window up it just makes a loud clicking sound like a solenoid kinda cluck. IT doesnt make that sound then i try to put it down or try the passender window. The passenger side works.
What it next. I tested voltage and I wasent getting the right amound during the problem. I think the next stepo would be to check the switch for a small malfunction. If the switch was bad then Y did it make a sound under the dash. If its not the switch then check the wiring for a short/brake in the wire... right? After that is the lock/window moduel.
sry got to go back to work. ill finish later.
Old August 1st, 2007, 02:29 AM   #2
Achieving more N/A power!
gills99stang's Avatar
When this baby hits
88 miles an hour...
gills99stang will become famous soon enoughgills99stang will become famous soon enough
Send a message via AIM to gills99stang
Are you sure the clicking sound wasn't the window off the track or anything weird like that?
Are you sure it's not getting the right voltage? I would compare it to the driver's side voltage.
Brendan
'99 Mustang GT [ 318 rwhp N/A ] - SOLD ()
'04 F150 XLT SuperCab
Old August 2nd, 2007, 05:34 PM   #3
Assistant to the Manager
Smoothgrandmama's Avatar
12 GT
8.46@88 1/8
Smoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really nice
iTrader: 6 reviews
Send a message via AIM to Smoothgrandmama Send a message via Yahoo to Smoothgrandmama
Mine Stopped Working one night.
But it worked the next day and has been working every since.
Might have just got water in it Idk
Join The MM Facebook:
Modded Mustangs Facebook
Vote For Modded Mustangs Ride of the Month
Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng
Old August 2nd, 2007, 09:36 PM   #4
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
Uh, that was real helpful!
2004 GT Boosted by Vortech
Old August 4th, 2007, 07:26 PM   #5
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
I just had the same problem and I posted on the svtperformance site. I pressed the switch in the up position with the power off, then while still pressing up on the switch I turn the power on and firmly closed the door. It actually worked
Good Luck
Build #1249
MM New Edge Crew Member# 6
Threads Similar to: window wont rull up and its raining.
Window wont go down! oasr87 Audio/Video 14 June 5th, 2008 07:34 AM
it was raining and i crashed my car nba1341 The Clubhouse 38 September 21st, 2007 03:09 PM
window wont go up ddashtrois 99-04 7 September 9th, 2007 01:37 PM
My Driverside window wont roll up. mustangmanic 99-04 11 September 4th, 2007 06:12 PM
raining in texas again 232stang The Clubhouse 26 August 18th, 2007 12:43 PM
