Another Dumb Engine Swap Question
Old July 30th, 2007, 06:17 PM   #1
OcOnnor220 can only hope to improve
What if I wanted to drop a Ford 3-Valve V10 motor in my 2001 Mustang gt...Would any of the Ford Mustang transmissions bolt up to this easily? Would I be able to use a stock Mustang drive shaft? What about the rear gear ratio? Would the block itself be able to fit in my engine bay without too much modification? As for what truck this came out of I can only assume a 2005-2006 Ford F-150, its a complete assembly. I wanted to do this with a Viper V-10 pullout but I measured the engine size and theres no way I could do it reasonably...unless I wanted to drive from inside the trunk.
Old July 30th, 2007, 10:25 PM   #2
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
that would be a unique project but is impracticle. that engine most likely wont fit, the aftermarket is small, and you'll probably have a hard time finding a trans. you would be better off swapping in a built 302, or stroking the 2V and putting a blower on it. and one more thing that V10 will weigh a ton.
ΜΟΛΩΝ ΛΑΒΕ
Old July 30th, 2007, 10:43 PM   #3
man_of_war2081 is on a distinguished road
Re: Another Dumb Engine Swap Question
Should fit in the engine bay, the 6.8 V10 is the same width an height as the 5.4 V8... the only thing that differs is length from the 2 extra cylinders of the V10 but will still clear the radiator.
As for transmissions, any transmission for the 4.6/5.4 should work, the V10 block is based of the modular V8 blocks so you can use the stock drive shaft too...
The other guy is right about the aftermarket for the modular V10 being next to none though but you can use the 5.4 V8 forged pistons and rods in the V10... but if you could fab up your own intake and turbo kit it would be a beast!
Old July 30th, 2007, 10:56 PM   #4
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
wow! that would be truly unique and i highly highly doubt that anyone in the world has a V10 modular mustang. Even if it is gonna cost a lot and b a lot of work... just think, "I'm the only one with a car like this."
Old July 31st, 2007, 12:08 AM   #5
marcfiebka is on a distinguished road
ya dude. dont let anyone tell you it cant be done. GO FOR IT!
Old July 31st, 2007, 01:05 AM   #6
i mean look at these damn honda crx's with blown big block 350's in em... i'm sure all of u guys have seen this on streetfire. If those guys can fit a 350 in a damn honda crx (1.6L vs 5.7) then you can do hell of a lot more to a stang enging bay... also have you seen that LS1 rx7, i personally wouldnt drive it, but its really neat.
Old July 31st, 2007, 01:54 AM   #7
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
wow i was wrong. thanks for correcting me. that would be a really unique project.
ΜΟΛΩΝ ΛΑΒΕ
Old July 31st, 2007, 01:52 PM   #8
Yeah it definately would be a cool project. its something I would look into if I had the money and knew someone that could fab up an intake and turbo for me... Those 3valve V10's make some nice power stock too (362HP and 457TQ)
Old July 31st, 2007, 02:00 PM   #9
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
Kenne Bell makes a supercharger for the V10s.
Kenne Bell
ΜΟΛΩΝ ΛΑΒΕ
Threads Similar to: Another Dumb Engine Swap Question
dumb question sb2f5marine69 5.0 Mustangs 2 July 11th, 2010 10:29 PM
might be a dumb question.... usmcsawgunner 5.0 Mustangs 22 October 9th, 2007 03:46 AM
dumb question here =/ Dustinv420 V6 Mustangs 4 March 11th, 2007 10:43 PM
dumb question antv20 General Tech 4 February 27th, 2007 09:05 AM
dumb question 4point6GT 96-98 4 June 26th, 2006 10:16 AM
