M/T ET Street
Got some ½ worn ET streets got a? They are 275-40-17 am putting them on 17x8 is 17psi ok. And where should I launch from and should I dump it?
Going to the track on Saturday
BBK cai P&P 75mmtb P&P plenum BASSANI exhaust MAC x-pipe NO CAT"S ACCEL direct fire coils NGK iridium spark plugs lX7 Eibach pro-kit springs |
I'd run like 15 or 14 psi heat them up real good and see how well it hooks up when ya dump it, then you'll know if you can dump it or have to feather it...
![]() 2004 GT Boosted by Vortech |
What rpm’s do you dump it at? I was thinking I would start at 5k what you think?
Blown 03 GT
5k sounds a lil high to me, i was wondering can u dump the clutch wit stock tires or do u need to ride it out a lil
#5 | |
I didnt think a 275 series will fit an 8in wide rim?
#7 | |
One Man Wolf Pack
![]() ΜΟΛΩΝ ΛΑΒΕ
I have the 315/35/17 MT's and I picked up 5/10's in the 1/4 the first time I used them. I was leaving at 4k and just dumping the clutch with 18 psi in the tires.
2000 GT 665/540rwhp/rwtq On pump gas Best 1/4 638hp street tune 11.01, best trap 134MPH, 80*+day, 10.5" DD Cobra R's & 315/35/17 DR'S DYNO VID ---> http://www.youtube.com/watch?v=K9uOS732mdA |
#9 | |
1965 Mustang Fastback
I'm a good boy now. [COLOR=red][B]slow car club - crew member 7 of 9 [COLOR=White]Mood: Cool :cool: [/COLOR][/B] [/COLOR] |
Achieving more N/A power!
M/T's hook better than any other tire out there.
Brendan '99 Mustang GT [ 318 rwhp N/A ] - SOLD ( )'04 F150 XLT SuperCab
#11 | ||
Sweet, I didnt think that size would fit our rims.. Thats helps me out alot too.
#13 | |
#14 | ||
Blown 03 GT
So the larger tires on a smaller wheel work well for drag radial but what about when ur runnin normal pressure wit street tires. I would think this would be a problem. Im curious cuz I wanna get 10" deep dish bullets for the rear wit street tires and was thinkin bout gettin drag radials for the 8s that are back there now, wut you guys think?
Proud American
Hey Matt just a heads up, I couldnt find anywhere around here that would put a 275 on my stock wheels, so I went with 245/45/17
#17 | |||
From what I've heard (and experienced), the Nitto and Sumitomo 315's don't usually rub. When I got rid of my Sumos and got BFG drag radials, they rubbed just a tiny bit when cornering hard on the driver side. I banged in a small metal section and no more rub.
My 315 MT's which are a little wider than the 315 nittos I have in the garage never rubbed. The offset of the rim would also have a little to do with it. Mine are 10.5" deep dish wheels.
I run the 275/17/40 MT E/T Street and I'm absolutely in amazement at your amazing feat of clutch dumping @ 4k RPM. Your my new hero.
![]() Hell, I dumped at 3,500 and bogged. Getting the 4.10 put in on Thursday, hopefully that'll cure having to ride the clutch out. (Not long, but my best 60' on the 3.27 was a 2.0 flat, I know that should be better, but couldn't launch as high without riding the clutch. I'd just fall on my nose like I stalled right after launch.) Also, for the record, MT E/T Street hook like hell at anytime for me. It's pretty incredible what these tires will do, even at a high pressure on the street. At the strip I run about 17, still experimenting. Everyone says to get these really warm. What kind of burnout should I be doing on these? Enough to see some smoke? A buddy of mine runs the same tire and his are at the tread wear bar after 4 passes and no daily driving. I'm pretty sure he overdoes it.
Threads Similar to: M/T ET Street
| tma street kit | flattusmaximus78 | V6 Mustangs | 49 | August 21st, 2007 08:44 PM |
| street/strip | angermgt | 5.0 Mustangs | 13 | May 12th, 2007 12:52 AM |
| street legal | acg | 96-98 | 12 | February 4th, 2007 02:15 AM |
| Whiteboy's 8 second street driven 280z street king | Mellon | Videos | 3 | December 27th, 2006 09:15 PM |
| InCarNitrousVid-On the Street. | Justincredible | Videos | 3 | December 24th, 2006 10:02 AM |
