Proud American
EGR Delete
Okay, so when I do my head swap and everything, I plan on deleteing my EGR. If anybody could help me out and give me everything I need to do and what I will need to buy. Thanks a lot!
I think I will get better responce in here even though I have a 96 GT!
Just need an egr delete plate and a tune.
![]() 2004 GT Boosted by Vortech |
Randy in parts at modulardepot.com will have what you need. The kit is around $12.
All you need is some gasket material, a piece of rubber, and a small illuminmun plate all cut the same diamond shape where the EGR is hooked up to and put that in place of the EGR. You'll need to disconnect that steel hose that runs to the exhaust manifold and block it off down there with a piping end cap the same size. Make sure you close off all the vacuum lines that ran from the EGR (there should be 2 or 3 small lines). Then use a handheld tuner to shut of the EGR sensors. That about does it. That mod makes the engine look alot cleaner!
Parting out 2003 SVT Cobra Air/Fuel http://www.moddedmustangs.com/forums...003-cobra.html Engine http://www.moddedmustangs.com/forums...003-cobra.html |
95 SVT Cobra
what about the smog pump? do you leave it in place and just put a cap over where the hose from the egr went? i would think it would be ok to leave it and do this?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Egr delete plate, i think upr has them for 10-15 bucks and then some sort of plug to thread into the header to plug up where the egr tube went, then any vacuum lines that might need plugged and a tune.
#7 | |
2011 Mustang GT
12.1 @ 116
Murdered.
Mods in garage. Built suspension and gears since posted times. |
Priest of the Car Gods
I'm curious as to why you would do this.
Is there a power gain to be had? Or is this just to clean up the engine bay? My knowledge of the EGR is that it only opens under light load when the engine is warm, and has a net effect of increasing fuel economy. It's the only peice of emissions equipment I'm aware of that (I thought) had no negative effects.
#9 | |
The tune just needs to turn of the cel. I haven't seen any cars react different during tuning and I with the delete I still got 28mpg with my supercharger. I know people will regurgitate the Wiki definitions eventually of the need for an egr and the science makes sense but still doesn't change my results.
#10 | |
You can get everything you need from Home Depot. I just cut out my own plate out of thick aluminum and bought some rubber caps to block the vacuum lines. Then just shut it off in your tuner.
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
KB'd GT
+1
Moderator
2012 300a gt auto
12.10@116
newer diablo's don't have the ability to shut off emission equiptment. you need to get a custom tune or find a older non-upgraded diablo.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
Safud: MM's Resident Hadji
Matt shouldn't have to worry about disabling anything as he swapped in a 351 and is not using the stock ECU.
April 2012 ROTM
I dont know why but I just dont like the idea of exhaust runnin back through a blower ( KB/Saleen/ Tork Tek kit)...can someone persuade me otherwise and save me $10-15? lol
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
do not delete your EGR, you will see 0 power gains, none at all, period. and can help cause your motor to detonate, EGR can help prevent this, do yourself a favor, keep the EGR
99 Cobra 03 Cobra motor AFCO H/E Pulley JLT CAI BBK L/T off road H/steeda catback SCT MAF Tune 03 cobra pumps HVGC |
April 2012 ROTM
you sad the key word..."detonate".....egr is stayin on! lol
Rollin' 18/ pushin' 2
Why exactly would rot running an egr system lead to detonation?????
April 2012 ROTM
holy shit lol I just looked how old this thread was!
Threads Similar to: EGR Delete
| Delete | HessiaN257 | Northwest | 3 | May 18th, 2008 12:16 AM |
| IAC delete? | acmillr | 99-04 | 12 | August 1st, 2007 02:37 PM |
| PCV Delete Kit | Murderjetz | V6 Mustangs | 14 | June 17th, 2007 12:44 AM |
| FMU Delete? Is It Possible? | wolffer | 96-98 | 1 | September 30th, 2006 02:46 PM |
| PCV Delete | AtlanticBlue99 | General Tech | 3 | March 16th, 2006 05:21 PM |
