New Suspension Set Up - Forums at Modded Mustangs
post #1 of 16 Old March 30th, 2013, 02:17 AM Thread Starter
So finally had the time to have my buddy help me install all my new goodies:
MM C/C Plates
MM Bump-steer
MM CO kit with Bilstein's
GMS K member and A arms
Everything fit fine, was worried about the GMS K member but it ended up lining up good. First time adjusting the CO and it was pretty slammed to the ground and took it for a test spin after bolting everything up and it ripped my fender lining out Is the lining really necessary?! Anything else I should look into replacing for the front end? My car is just a DD and I use it to commute to work.
Currently sits up about an inch higher then it is in this pic and I don't have any rubbing issues or issues with my tires ripping my liner out. . .
35th LE 99 GT
FourSix is offline
post #2 of 16 Old March 30th, 2013, 02:30 AM
Couple things. One, I want more pictures! Two, did you roll your fenders? Lastly, the inner well liner keeps dirt, mud and debris from flinging into everything.
2003 DSG GT COUPE / 5 Speed/Bolt ons/Exhaust/Corbeau/FR500/Canton/MM coilovers/H&R SS/Mach 1 Delete/SSBC Big Bite Rotors/ MMR RS Delete/MM CC plates/UDP
Broke is offline
post #3 of 16 Old March 30th, 2013, 02:36 AM Thread Starter
Lol, I'll post some once I clean up the car a bit, and yes fenders are rolled. Car needs an alignment badly also. . . will get one tomorrow morning hopefully
35th LE 99 GT
FourSix is offline
post #4 of 16 Old March 30th, 2013, 02:45 AM
That is exactly where I want mine to sit. I'm about 1/2 inch from that. What ball joints are you running? I'm about to order Steeda x2 ball joints
Broke is offline
post #5 of 16 Old March 30th, 2013, 03:09 AM
Xx1nuYashaxX's Avatar
If it makes you feel better, I haven't had the liners up front for the two years I've owned mine. Did as well through rain, snow etc. It gets dirty much faster which sucks, and be careful with the doors. It allows gunk, rocks, sniw, salt, etc to enter where your hinge is. Hard to clean and depending on what is there will scratch your paint or make it creak when you open your door.
---------- Post added at 03:09 AM ---------- Previous post was at 03:08 AM ----------
DD as well*
Xx1nuYashaxX is offline
post #6 of 16 Old March 30th, 2013, 08:22 AM
Wooboost283's Avatar
Holy sex!!!
Wooboost283 is offline
post #7 of 16 Old March 30th, 2013, 11:29 AM Thread Starter
Just the ones already on the gms arms. My buddy says he had those ball joints and it didnt seem like it dropped his car at all. he didnt use the spacer either. Only problem going that low is setting the bump steer and obviously rubbing.
35th LE 99 GT
FourSix is offline
post #8 of 16 Old March 30th, 2013, 11:41 AM
Anandavenkatakrishnan
dsgpony's Avatar
Looks good. How does it handle now?
'04 DSG GT- Sold
'14 Sterling Grey GT (Megalodon)- Roush Blower, Longtubes, Coilovers, Brembos, Niche Wheels, a lot of other things. 615RWHP
dsgpony is offline
post #9 of 16 Old March 30th, 2013, 11:57 AM Thread Starter
Had to baby it home since the alignment was way off. Going in this afternoon and I'll let you know after. So far with 175lb springs it was smooth though
35th LE 99 GT
FourSix is offline
post #10 of 16 Old March 30th, 2013, 01:02 PM
Rub at full lock?
Broke is offline
post #11 of 16 Old March 30th, 2013, 01:13 PM
va boy's Avatar
Very nice! Can you tell any difference since installing the bump steer?
03 Sonic Blue Terminator
va boy is offline
post #12 of 16 Old March 30th, 2013, 02:18 PM
iTrader: 16 reviews
your car will manhandle turns with my mm pan hard bar i have for sale
looks good i need to get a tubular k soon too
2003 GT stock
2006 Spec V daily driver corner craver
1_nice_03_gt is offline
post #13 of 16 Old March 30th, 2013, 08:25 PM Thread Starter
Ugh look like they are unable to to align it to spec. Something must be wrong. The guy said if I lower it more it'll help with adjustment lol... I guess I'll get a small spacer so I don't rub when I lower even more now
35th LE 99 GT
FourSix is offline
post #14 of 16 Old March 30th, 2013, 09:00 PM
Mustang_Girl_32's Avatar
iTrader: 38 reviews
I hope mine will be just as an easy install. How was the cc plate install? I have to install those, bumpsteer, control arms, k member, coilovers on tokico illumina struts
Procharger P1sc| 2 core| 353hp/347tq| Mac lt's| lethal x| slp lm1| 75mm tb/plenum| 4.10's| lca| flsfc| h&r's
Oh ya, and female owned and driven!
Sonic Blue Crew
Mustang_Girl_32 is offline
post #15 of 16 Old March 30th, 2013, 09:29 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
Looks really good, what are you running out back?
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
11.50@121.77@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #16 of 16 Old March 30th, 2013, 10:18 PM Thread Starter
My buddy had a little trouble drilling through but other than that it was easy.
Just shocks and springs. Abou to pick up Some MM adjustable LCAs until I find an IRS and run full tilt boogie racing bushings.
35th LE 99 GT
FourSix is offline
Human Verification
