Vortech 10psi 4.56 gears 5spd weight reduction 2step!!!!!!! - Forums at Modded Mustangs
post #1 of 36 Old March 30th, 2013, 03:27 AM Thread Starter
Send a message via AIM to kennyGT
Get you're attention?
lol
Well i've finally decided to get off the juice and make my way to boost.
The car has been gutted of all seats and trunk interior trim to replaced with summit racing buckets. heater core entire a/c system pulled out, radio and such gone.
Need to sell the rest of this crap to finish purchasing everything, but heres a rundown of the set-up black being what i have, red is what i need
Suspension:
96 cobra 8.8
31 spline Moser axles
31 spline Strange spool
4.56 Motive gears
C-clip eliminators
Upper and lower control arms
Eibach Pro kit springs
KYB Gr2 shocks
tubular K-member
Motor:
Pacesetter Longtubes
Pacesetter X-pipe
Dynomax Race bullets dumped
Vortech V2 Kit 10psi
MMR 7qrt oil pan
anderson power pipe
BBK 78mm Throttle Body
Hi-Tech Blower cam
90mm MAF
40lbs injectors ?????
340lph fuel pump????
solid motor mounts
Things with ??? are uncertain still for obvious reasons.
Stuff i need advice on is tire selection. Obviously going with a 28" tire. Just unsure if with my suspension set-up should i go with a et drag radial, or et street cheater slick. now i know this is tricky cause sometimes a drag radial is better with certain set-ups compared to a cheater slick. dailly driving is not a concern also the rear being a 96 in a 99-04 body i don't think i can get away with more the a 275-60.
MSD 2 step or N2MB????? What i want is to be able to be consistent at the track as well as be into boost at launch. With a 4,500rpm launch think i will be able to see 8psi? with time I will replace the cheap suspension parts with better quality and performing parts meaning maybe higher launches.
Other than that i'll keep ya guys posted, pics will be rolling in soon i wanna get the motor out and a few things cleaned up before i start setting everything up.
let me know what ya think!
07 GT/CS manual - STOCK
88 LX automatic-SOLD
01 GT manual-UNDER CONSTRUCTION
97 GT automatic-SOLD
kennyGT is offline
post #2 of 36 Old March 30th, 2013, 07:08 AM
RedFire Venom's Avatar
iTrader: 6 reviews
First off make your own powerpipe. You'll save a boat load and get a little more power. Also depending on the power you're wanting you might need a dual hat or BAP (the 340 is capable to 550~). As for injectors I'm guessing you're wanting big power so id go 60# injectors. Also the TB is not the restricter, the plenum is. So make sure you get a different plenum. As for the 90m MAF do not cheap out with the lightning MAF. It pegs easily and you'll most likely want the pmas slotted 05-09 MAF or the SCT BA MAF.
That covers most of it, but if you're truly looking for good times you should definitely look into suspension. Without it you're not goin to put much power down. Take f8l for example - 100% stock and he's running mid 12s. But he's got a helluva suspension.
Edit: Just noticed you have some suspension work done. Definitely get some flsfc before you hit the track. It'll help for sure and its pretty cheap (~$125 if you can weld yourself) and takes about 2-3 hours.
That's why we give cars female names, because we enjoy shaving their parts.
RedFire Venom is offline
post #3 of 36 Old March 30th, 2013, 07:48 AM
Wooboost283's Avatar
60lbs injectors and 340lph pump and don't look back. No, ifs, ands, or buts
Make your own dam power pipe here for 30$ lol
Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts
45 degree 4" foot long aluminum pipe and a 4" to 3.5" bending reducer to your liking.
---------- Post added at 06:45 AM ---------- Previous post was at 06:45 AM ----------
Also how awesome is that 4.56 gear?
---------- Post added at 06:48 AM ---------- Previous post was at 06:45 AM ----------
I also dead hook on the street and track with a m/t et street radial with 450rwhp and a 4.10.
Wooboost283 is offline
post #4 of 36 Old March 30th, 2013, 08:09 AM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
Car must be a blast with 4.56's. if my car was setup cor 1/8th mile, I'd run 4.56's.
Good luck with the build man!
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is online now
post #5 of 36 Old March 30th, 2013, 10:18 AM
JayC's Avatar
How did you possibly run the time of 12.67@110.34 on nitrous? If that is a N/A time then what was your N20 times? Just to let you know a 150 shot will usually out-perform a 10psi blown car if set up properly.
12.25 @ 111 mph w/ CMS stage II cams
10.95 @ 119 mph NX 150 shot
6.96 @ 102 1/8th mile
Best 60', 1.43
JayC is offline
post #6 of 36 Old March 31st, 2013, 12:47 AM Thread Starter
gear are awesome, im a loner without a go pro so i never have proper video but these will do
this is on motor 10mph-100mph
4.56 gears 01 mustang GT - YouTube
i ran 12.67@110 on a 125 shot about 3-4 years ago back then i had cheater slicks, h pipe and dumped bullets only on the stock everything and original 2001 motor. motor in the car now is from an 06 f150 2v since then i swapped exhaust and bought a jlt ram air, deleted the a/c and bumped to a 175
well really fugged up this run i just couldnt get my launch right cause im on a micro switch no wot or window switch. 4k launch car almost turned off finished the run in 4th 5,800rpm's
1/8th mile at lakeland dragstrip - YouTube
8.3@84mph 1/8th mile 2.2 60'
never had the time to run quarter mile cause i work 40 hours just between friday-sunday and wednesday 1/4 was not avail.
plus i was busy with my 88 lx at the time which was running 12.00@112 on motor and had a 175 shot that i couldn't spray at the track lol
kennyGT is offline
post #7 of 36 Old March 31st, 2013, 03:11 AM
_
iTrader: 13 reviews
If your running all of this on the stock block, you won't need anymore than 42#'s, and a 300 lph pump.
x7sage7x is offline
post #8 of 36 Old March 31st, 2013, 04:22 AM
stal94gt's Avatar
What trans are u running? That would be my second concern next to the rear. As for tires slicks all the way. They are weigh less and why not have the best traction.
bone stock from the factory!
stal94gt is offline
post #9 of 36 Old March 31st, 2013, 08:16 AM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
Well, hello stranger
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #10 of 36 Old March 31st, 2013, 10:46 AM Thread Starter
3650tr for now. but when that goes i'll make the decision on what is next
kennyGT is offline
post #11 of 36 Old March 31st, 2013, 10:47 AM
Mr. Stangarang
04MidnightGT's Avatar
iTrader: 5 reviews
MSD 2 step > N2MB.
USAF E-5
IG @ nj_5oh
Current Vehicles
14' Mustang GT "Alexandria" - Paxton Supercharged
15' GSX-R 600
Sold Vehicles
08' Lancer Evolution X MR
04' Mustang GT - Single Turbo
04MidnightGT is offline
post #12 of 36 Old March 31st, 2013, 02:40 PM
_
iTrader: 13 reviews
Originally Posted by 04MidnightGT View Post
MSD 2 step > N2MB.
Really? Does a 2 step have no lift shift?...... Nope.
And a 2 step is overpriced.
x7sage7x is offline
post #13 of 36 Old March 31st, 2013, 04:37 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
You don't need no lift shit.
F8L GT is offline
post #14 of 36 Old March 31st, 2013, 10:43 PM
_
iTrader: 13 reviews
I do, I power shift.
x7sage7x is offline
post #15 of 36 Old March 31st, 2013, 10:45 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
You can power shift just fine without it
F8L GT is offline
post #16 of 36 Old March 31st, 2013, 10:51 PM
_
iTrader: 13 reviews
It would still be nice to have a N2MB hold the RPM rather than have it sky rocket. I power shift quick but it still gets in the red.
x7sage7x is offline
post #17 of 36 Old March 31st, 2013, 10:53 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
Not quick enough if it just up that far
F8L GT is offline
post #18 of 36 Old March 31st, 2013, 11:39 PM
p4ndiamond's Avatar
MSD 2 step > N2MB.
How so ?
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Pi intake Hitech stage 2 cam, Vortech V7-JT Alum drive shaft. Lowering kit x2 ball joints Koni DA, H&R Super race spring LCA "
p4ndiamond is offline
post #19 of 36 Old April 1st, 2013, 01:06 AM Thread Starter
hahahaha i was so ready for this when i was scrolling down
kennyGT is offline
post #20 of 36 Old April 1st, 2013, 01:44 AM
_
iTrader: 13 reviews
Ya, I figured he would say something like that. N2MB is still better. You can hook up to it and tune EVERYTHING, but a 2 step just has a dial on it.
Sent from AutoGuide.com App
x7sage7x is offline
Human Verification
