What exactly is happening when you throw a rod threw your block? - Forums at Modded Mustangs
post #1 of 30 Old April 18th, 2013, 05:07 AM Thread Starter
GM2Ford's Avatar
What causes this primarily, detonation?
1991 Camaro RS - Sold
1989 Iroc-Z28 -Sold
1999 Mustang GT - Under Construction
1993 Ford Escort - Sold
http://www.moddedmustangs.com/forums...v-4v-swap.html
^1999 GT w/ 2001 Cobra Motor w/ 2004 Eaton Swap^
GM2Ford is offline
post #2 of 30 Old April 18th, 2013, 06:24 AM
jeep45238's Avatar
Usually a lubrication problem, or RPMs too high.
USAF E4 ~ Never settle for the ordinary.
Rights cease to exist when restrictions are put on them.
jeep45238 is offline
post #3 of 30 Old April 18th, 2013, 06:57 AM Thread Starter
GM2Ford's Avatar
Hmm... can any elaborate a little more on this? Like while the RPM's are too high, whats happening inside the engine causing it too throw a rod? Or when there's not enough lubrication whats happening inside the cylinders?
Also, does detonation occur more so in boosted cars?
1989 Iroc-Z28 -Sold
GM2Ford is offline
post #4 of 30 Old April 18th, 2013, 07:00 AM
jeep45238's Avatar
Oil starvation/foaming. It can even be a time when it was ran low on oil a year ago starting to rear it's head now (burned/leaked/wasn't filled properly after oil change).
The higher the cylinder pressure/temperatures, the higher the risk of detonation (so yes, for boosted).
post #5 of 30 Old April 18th, 2013, 07:01 AM
MM's V6 Hater
iTrader: 31 reviews
Shit is spinning too fast and fucking shit up. don't over rev.
2013 GT
2016 F150
Cabikejumper is offline
post #6 of 30 Old April 18th, 2013, 08:57 AM
is Torgo
WickedSnake00's Avatar
Simply put: exceeding the design limits of the conrod. This is usually due to excessive force, whether from high speed or high combustion chamber pressure. The combustion chamber pressure can be due to sheer (not SHEAR) power, or due to abnormal combustion dynamics, such as detonation, which dramatically raises cylinder pressure.
Lubrication issues typically do not cause catestrophic failure in this manner. Those are more likely to cause you to spin a bearing or get severe rod knock.
WickedSnake00 is offline
post #7 of 30 Old April 18th, 2013, 08:58 AM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
My last engine had detonated and then shot the rod out the block.
853rwhp @ 23psi
75mm Turbo 5.4 swap E85
#turbo2v
10.11 @ 138mph STOCK LONGBLOCK
9.11 @ 149mph - New Longblock /w Powerglide
www.JPCracing.com 410-729-0005 ext. 11
PM me if you need any parts or advice!
sharkbait is offline
post #8 of 30 Old April 18th, 2013, 09:54 AM
RedFire Venom's Avatar
iTrader: 6 reviews
That's why we give cars female names, because we enjoy shaving their parts.
RedFire Venom is offline
post #9 of 30 Old April 18th, 2013, 10:09 AM
Chitty Chitty Bang Bang
OxfordGtWhite's Avatar
My last motor had a clogged oil galley in the crank on cylinder 8. Instead of spinning a bearing it decided to sieze the connecting rod to the crank, snap the rod, and fling that bitch out the side of my block. I've seen plenty of carnage like this in high horsepower applications but nothing like this in a near stock N/A setup.
DRIVETRAIN: Spec billet aluminum flywheel, Spec stage 1 clutch, Steeda Tri-ax short shifter
ENGINE: Police Interceptor long block, AM CAI, Diablosport Predator tuner,Bassani O/R X,Dynomax flow tubes, Magnaflow Magnapack mufflers, no tail pipes
OxfordGtWhite is offline
post #10 of 30 Old April 18th, 2013, 10:25 AM
Mr. Stangarang
04MidnightGT's Avatar
iTrader: 5 reviews
I may have ran a little bit more boost than my car was tuned for and I bent a rod lol.
And my current internals
USAF E-5
IG @ NJ_5OH
Current Vehicles
14' Mustang GT "Alexandria" - Paxton charged
15' GSX-R 600
Sold Vehicles
08' Lancer Evolution X MR
04' Mustang GT - Single Turbo - 396 RWHP 460 RWTQ
04MidnightGT is offline
post #11 of 30 Old April 18th, 2013, 10:25 AM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
853rwhp @ 23psi
#turbo2v
post #12 of 30 Old April 18th, 2013, 10:47 AM
USN03GT's Avatar
DAMN that shit exploded
Teskid block 20 over all forged stroker kit Crower stage 2 blower cams Trickflow track heat heads stainless steel headers
http://youtu.be/9W7MKjLDJRo
USN03GT is offline
post #13 of 30 Old April 18th, 2013, 01:11 PM
prorider46's Avatar
not a car, but here is a old pic of my 450r when its rod let go...
prorider46 is offline
post #14 of 30 Old April 18th, 2013, 01:17 PM
M112'd Sixxer
Im trying to pump 13psi through a v6 with 150k miles on it... ill definitely have rods blasting out of the block.
Garage:
1999 Mustang V6 M112 4R70W (Elise) Sponsored by Ortiz Performance
2013 Fiat 500 Turbo C510 (Rosso Rocket)
Fink is offline
post #15 of 30 Old April 18th, 2013, 01:42 PM
a.k.a. Racecougar
Tang Stang's Avatar
There are myriad ways to destroy a connecting rod. I had a timing chain fail in a 5.0L while cruising at ~2K rpm on the highway. The chain wrapped up around the crank gear and all hell broke loose.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Tang Stang is offline
post #16 of 30 Old April 18th, 2013, 01:54 PM
M112'd Sixxer
Now that is carnage!^
Garage:
Fink is offline
post #17 of 30 Old April 18th, 2013, 02:29 PM
02TrickFlowGT's Avatar
Raw
Built, Forged, 5litre, Turbo cams, Turbo comming soon!
02TrickFlowGT is offline
post #18 of 30 Old April 18th, 2013, 02:37 PM
bigjohnstud4200's Avatar
I had a bend rod due to hydro lock, basically, water was sucked up through the air intake and made it into the cylinders.. it's hard to compress liquid!
Tuned by Joe@TrickTuners
CMS Stage 1 Cams, 4.10 Gears, TrickFlow 70mm TB & Plenum, MAC Prochamber with Pypes M80's, MGW Shifter, Custom Paint, Cobra Cloth Top, Staggered Chrome 18" Saleen's and Sequential Tails.
bigjohnstud4200 is offline
post #19 of 30 Old April 18th, 2013, 02:49 PM
a.k.a. Racecougar
Tang Stang's Avatar
Yep, that's yet another way. The rod hanging on the wall to the right of the shelf was bent via hydrolock.
post #20 of 30 Old April 18th, 2013, 03:21 PM
Mechanical Engineer
nathanielwilliam's Avatar
Hydro lock bent a rod in my 2001 GT. It definitely doesn't pay to have one of those cheap CAI's that put the filter in your bumper/fender well. I managed to suck enough water up driving 45mph down the interstate in the rain.
2006 Mustang GT
Pacesetter Ceramic L/T's
Pacesetter H-pipe
FR hot rod cams
FR Intake manifold
FR500 exaust
Hurst Competition Plus Short throw.
JLT CAI
2002 F-150
Sold:
2001 Mustang GT (miss this one)
nathanielwilliam is offline
Human Verification
