Removing Front Brake Rotors
Old August 4th, 2007, 09:25 AM   #1
OcOnnor220 can only hope to improve
Its not the rotor Im having trouble with, its the caliper housing on the rotor of my 2001 GT. I have all the tools I need, but those two bolts that hold that thing on are on so tight I cant even leverage them the LEAST. Has anyone used a motorized torque wrench for this or am I missing something stupid like the bolts are screwed on counterclockwise or something...BTW, I go to the gym 3 times a week and I work for UPS so no fucking 'weakling' comments, this question is only for people who have answers to it thank you.
Old August 4th, 2007, 09:35 AM   #2
Nevermind I got one, I could've pulled a fucking TREE out the ground with that much force...Just gonna be a long day thats all, sorry I guess all you assholes have no use for those smart-ass retarded wisecracks you woulda used...maybe next time. Beyond that, the stainless steel brake lines...I may check back later if I still need help but is it easier to just disconnect the stock lines, drain all the fluid and then fill it up with new fluid when I get the assembly on? Seems easier..Ill probably do that. Later.
Old August 4th, 2007, 02:42 PM   #3
99spaded is on a distinguished road
Hey man yeah those bolts on my car were a bitch!! And i did the ss brake lines and love em, the brakes are going to feel a lil different at first but once you get used to it there are great!!! And you also might want to do a pressurized bleed on your brakes, i fought with it for a while and then gave up!! Got it done for 20 bucks!! Good luck!!
Old August 4th, 2007, 05:51 PM   #4
superbeef1000's Avatar
i had to use a breaker bar to get mine loose
Threads Similar to: Removing Front Brake Rotors
brake rotors/wheel size Bhblondguy 2005 - 2010 5 October 11th, 2007 01:58 PM
Best brake rotors neckbonekat 99-04 4 August 28th, 2007 03:31 PM
Brake rotors Stangzilla 5.0 Mustangs 5 May 8th, 2007 09:59 PM
brake rotors?? burnout5.0 99-04 3 April 13th, 2007 11:12 PM
