98 Cobra Motor --> 01 GT Swap
Old August 5th, 2007, 10:47 PM   #1
marcfiebka is on a distinguished road
How much work would this take? How much would it cost etc?
Would my current transmission bolt right on (3650)?
I can get the motor but the guy says I will need a Cobra Computer and a radiator. What do you guys think? How much would it cost to get it up and running? Lets assume the motor is going to run me $1100.
By the way it has 80k miles on it and a spun rod bearing that needs to be fixed.
Old August 5th, 2007, 11:29 PM   #2
02StangGToWNEr's Avatar
2006 Mustang GT
02StangGToWNEr is on a distinguished road
You can always go check WWW.MPSAutoSalvage.COM
They usually have great deals on used engines, and better engines than the 98 Cobra. It's just my opinion, but I would try to get a 03/04 Cobra engine. Either way let us know what you do.
Old August 5th, 2007, 11:45 PM   #3
MATT02GT's Avatar
MATT02GT is a jewel in the roughMATT02GT is a jewel in the roughMATT02GT is a jewel in the roughMATT02GT is a jewel in the rough
I dunno if it would be worth it unless you plan on building it up
Bolt on list in Garage..
Old August 5th, 2007, 11:56 PM   #4
well i need to pass emissions...and the 03 cobra motors are about 8-10k on ebay. im definitely on a budget.
Old August 6th, 2007, 12:10 AM   #5
2006 Mustang GT
You should be able to get a used cheaper then that. If not, I would just get a crate engine, they are usually cheaper & have more power than Fords standard engines. If thats what you can afford though, then buy it ya want.
My Cardomain Page:
http://www.cardomain.com/ride/3103321
Old August 6th, 2007, 12:45 AM   #6
the only crate engines ford sells for our cars is the mach 1 engine and the 5.0 "cammer". the mach 1 is 6k and the cammer is 15k. the other small blocks need to be carbuerated (sp) and dont pass emissions
Old August 6th, 2007, 05:49 PM   #7
2006 Mustang GT
What I was saying is do a search, because there are better engines that you can swap, that are made for the Mustang GT, but NOT made by FORD.
My Cardomain Page:
Old August 6th, 2007, 06:38 PM   #8
MATT02GT's Avatar
Check out VT engines and some other companies out there
Old August 6th, 2007, 07:19 PM   #9
1999 Mustang
Invictus is on a distinguished road
You'll need an 8 bolt flywheel and probably a stronger clutch to hold the added power for your 3650 to bolt up. That's easy...
Your GT ECC and radiator will suffice if you're on a tight budget, but i'd change the radiator out eventually.
You can use your GT harness with a few modifications made to work on the cobra motor. It should bolt right in no issues. It'll be a little larger though up top with the 4V heads, so removing the valve covers will be a total bitch. You're going to have to take out the hydroboost unit completely just to remove the driver's side valve cover...
It's a relatively easy swap though, I just put an 04' motor in my 04' GT.
Threads Similar to: 98 Cobra Motor --> 01 GT Swap
1996 cobra swap with 03 cobra heads and supercharger. stan's96snake 96-98 14 October 30th, 2010 04:57 PM
03 04 cobra motor swap 2 91 coupe? kngkahious 5.0 Mustangs 32 October 23rd, 2007 04:27 PM
99 4.6 cobra motor swap into a 2000 Gt Cantbeatblack 99-04 4 August 6th, 2007 01:22 PM
97, 03 04 Cobra Motor Swap bigmike83 96-98 20 November 9th, 2006 04:38 PM
Motor Swap 68 dlxcoupe 96-98 3 November 1st, 2006 02:44 PM
