vibration in clutch pedal? - Forums at Modded Mustangs
post #1 of 10 Old May 11th, 2013, 05:25 PM Thread Starter
Boost Bro
bullitggt's Avatar
So I just installed my new clutch (UPR KING COBRA) about 4 days ago, got 200 some odd miles on it. For some reason since I installed it, I have this weird vibration issue in my clutch pedal when its released. It has a brand new ffrp Tob so idk why it would be vibrating, I made sure to do everything right with this clutch install. Could my cable be too loose? I have the mm quadrant and adjuster.
2000 GT
2010 GTI = Stage 2 Daily
Cammed+Intercooled Vortech S Trim
441 rwhp / 390 rwtq @ 7psi
Instagram @Patrykd07
bullitggt is offline
post #2 of 10 Old May 14th, 2013, 02:31 PM
Bates TTwins's Avatar
I had the same problem the clutch pedal had a horriable shake and I replaced the clutch flywheel and tob. It was the tob but replaced the clutch while the trans was out
Bates TTwins is offline
post #3 of 10 Old May 14th, 2013, 02:43 PM
grubiaco's Avatar
iTrader: 5 reviews
Most likely the cable
Sent from my DROIDX using AutoGuide.Com Free App
Exterior is all done. Now its time she gets force fed.
grubiaco is offline
post #4 of 10 Old May 14th, 2013, 03:48 PM
IsaidWOT's Avatar
I was gonna say cable also.
2008 Jeep Wrangler Unlimited
2002 Laser Red GT - Sold
Laser Red Crew, Founder
IsaidWOT is offline
post #5 of 10 Old May 14th, 2013, 03:55 PM
Like A Boss
crackpotfox's Avatar
Tob. The pedal vibrates when the bearing starts going bad.
Carolina Crew #54
Always Clean Crew
Originally Posted by narleycarley View Post
I coached his boy in basketball last season. Giggity giggity
crackpotfox is offline
post #6 of 10 Old May 14th, 2013, 04:57 PM
grubiaco's Avatar
iTrader: 5 reviews
He just changed it.
grubiaco is offline
post #7 of 10 Old May 14th, 2013, 06:24 PM
JayC's Avatar
Take the slack out of the cable. The cable should be tight enough that the TOB is barely touching the pressure plate fingers.
12.25 @ 111 mph w/ CMS stage II cams
10.95 @ 119 mph NX 150 shot
6.96 @ 102 1/8th mile
Best 60', 1.43
JayC is offline
post #8 of 10 Old May 14th, 2013, 06:55 PM Thread Starter
Boost Bro
bullitggt's Avatar
well its a crappy cable I got from pepboys when mine snapped, but its been through alot, you guys think I should just order a nice new MM cable again?
2000 GT
post #9 of 10 Old May 14th, 2013, 06:58 PM
JayC's Avatar
Hell no!!!!! OEM cable only, every thing else is junk!!!!!
Best 60', 1.43
JayC is offline
post #10 of 10 Old May 14th, 2013, 11:23 PM Thread Starter
Boost Bro
bullitggt's Avatar
I totally see what you mean, with the car running I felt the vibration be completely in sync with the cable when I felt it, It must be routed wrong or something, but it almost seems to short because its a cheap replacement. How does the cable route exactly? under the engine mount and over the k member right?
2000 GT
Human Verification
