![]() iTrader: 1 reviews
Crower cams
So I need to get some and ive heard that crower is the better brand
so im asking, should i get a stage 3 in a low lift design or stage 3 in a high lift design or something else? im going by their website and i want a mean sound with a pretty good increase in mid-high range. Thanks.
2000 Mustang Gt
13.56 @ 106
you do know with stage 3 youll probably have to do some internal work right?
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams Manley Valves/Springs - Centerforce Dual Friction BBK LT's - BBK o/r H - Bassani catback FRPP 4.10s - XCAL2 - BBK UDP's 306rwhp/333rwtq |
haha never crossed my mind. just thought theyd operate at....lower capacity with stock internals.
2000 Mustang Gt
13.56 @ 106
no, even with stage 2 you have to change the pistons or modify them becuase they hit due to the high lift. only stage 2 cams you can do with out modification is vt stage 2. but remember you will need new valve springs with stage 2 or higher
yeah i was aware of the valve springs part, but everything else i really didnt think about. i was hoping i could do all those 2 without taking the engine out, but pistons...ugh damn
2000 Mustang Gt
13.56 @ 106
i forget what actually happens with the pistons hitting, some1 else can probably explain it, but i know it happens lol
if you car is a DD i wouldnt go higher than stage 2 im picking up vt stage 2 over this winter for next season
why no higher than stage 2 for a DD?
but should i go high lift or low lift and whats the difference?
unless you have the heads for them, anything over a stage 2 cam is just noise. vt is the only stage 2 cam that wont hit the piston(some comp 270 cams wont but your taking a chance)
I'd go stage 2 vt, all the vids I've heard of them sound sick as hell
![]() 2004 GT Boosted by Vortech |
what about stage 2 crower?
and again whats the diff between low and high lift
Here's vt stage 2 cams
http://www.youtube.com/watch?v=YB53GQoUmmo And all I could find was stage 3's for crower cams... http://www.youtube.com/watch?v=vQK475c9YQg As for technical questions I dunno shit about cams... lol
the lift is how far the valve is compened. a high lift will push the valve off its seat alot more than a low lift cam. but you can only go so far before the valve will hit the piston.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the differences will be is the low lift is a longer duration. they both are made for specific reasons. either way the motor will need to be able to turn over 6500+ rpm's for them to work correctly. each cam is made to do certain things, thats why you need to know what you want, need, what will work, and what to look for in a cam. it is very easy to over cam a motor, and as expexive as cams are for the modulars thats the last thing you want to do.
so what is the stock lift on the PI cams. I've talked to the comp cam tech line and all the extreme energycams for the 99+PI motors have 550 lift but the guy said that i would need to notch the pistons. He Also said that there are around 7 different piston makers for these cars, any truth to that. I want cams but the VT stage 2 have a 108LSA and thats not the best for a nitrous or super charged car, the comp 270s have 113LSA but there is a chance of PTV contact.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
#15 | |
2000 Mustang Gt
13.56 @ 106
is stage 2 too much for a non built motor?
2001 Mustang SVT Cobra
Could be, should be fine.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
#18 | |
mm's nitrous mod
2000 mustang gt
nitrous cams and blower cams are pretty damn close to the same. unless you have a specific application, there is no difference from most companies. there are a few that will distinguish specifics for nitrous, s/c's turbo's, and even for a roots or a twin screw.
Sometimes I think I'd rather just overcam the hell out of my car and sit around idling all day.
Threads Similar to: Crower cams
| VT, Crower, or COMP | TheBusher | 99-04 | 36 | December 24th, 2007 07:25 PM |
| Crower Cams | MustangJon255 | 2005 - 2010 | 1 | July 9th, 2007 09:02 PM |
| Crower Stage 3 cams | Norse1974 | 2005 - 2010 | 42 | June 30th, 2007 11:54 PM |
| crower NPI cams | Monster stang 97 | 96-98 | 24 | May 23rd, 2007 07:04 PM |
| Crower cams or COMP | wirenut666 | 99-04 | 1 | March 8th, 2007 07:37 PM |
