03-04 Cobra Blower on an 01 Cobra?
Old August 7th, 2007, 12:47 PM   #1
xx9gt6xx is on a distinguished road
Send a message via AIM to xx9gt6xx
Hey guys I'm sure this has been asked before but I haven't been online in months. Will an 03-04 Cobra Supercharger (Stock Eaton) fit on an 01 Cobra? I know that if it will some modifications may be needed to make the system work but is there anyone who has heard of this being done or know of a website where I can get more info on this setup? Thanks...
...Modded 1996 Ford Mustang GT... SOLD!!
...Modded 2001 Ford Mustang SVT Cobra... SOLD!!
Now...
...Modded 2003 Ford Mustang SVT Cobra, Anniversary Edition..
www.cardomain.com/id/po1snd_u
Old August 7th, 2007, 01:01 PM   #2
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
manifold
wiring harness with fuel rail and injectors
heat exchanger
inter-cooler
Intake (TB/Plenum)
upper tensioner bracket
lower pulley
Inter-cooler piping, pump and tank
alternator and bracket
03 cobra front timing cover
03 cobra harmonic balancer
03 cobra pump
inlet tube and maf
A tune
alternator and 2 brackets
power steering lines need to be relocated
power steering pulley
And you should get the unit ported as well.
You might find an Eaton for $500-600, add all this and it's not a good deal anymore. You'll be looking at under 430 HP for all that as well...
IMHO, not worth it. You can also get heads for more power and definitely look into a forged bottom. I think you'd be better off with a Pro Charger or Whipple. It will be cheaper than going with the above hassle.
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old August 7th, 2007, 01:04 PM   #3
Nate's4.6 is on a distinguished road
Exactly what was posted.
I will not be worth the money invested for the power outcome.
www.fquick.com/Nates4.6
Old August 7th, 2007, 01:55 PM   #4
Thanks guys. I didn't know a thing about the swap and now after looking at what I'd have to go through and seeing the power output just turned me off on that idea. Well, looks like just upgrading to an 03 Cobra doesn't sound so bad afterall...
Now...
Old August 7th, 2007, 02:16 PM   #5
04GTAMPA's Avatar
Well, you def leaped a good distance from the 96 to the Cobra. If financially makes sense, go ahead. They are def worth it.
Threads Similar to: 03-04 Cobra Blower on an 01 Cobra?
which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt gtjason New Members Introductions 14 February 19th, 2012 09:19 PM
94 Cobra with blower troy1000rr 94-95 8 May 23rd, 2007 09:08 AM
2003 cobra blower pulley 969800gt 99-04 1 April 17th, 2007 01:02 PM
which blower for 96 cobra 342stroker Modular Mustangs 5 February 15th, 2007 06:04 PM
1994 Cobra With Blower troy1000rr General Tech 18 December 21st, 2006 06:55 PM
