HELP! my 99 GT won't start
Old August 8th, 2007, 07:46 AM   #1
VIRstang is on a distinguished road
My 99 GT 4.6 track car won't crank. We were putting new adjustable struts on all four corners this weekend. We put the rears on and drove it around the neighborhood. It handled so much better. Then we put on the front struts. When we went to test drive the car, it wouldn't crank. We did leave the ignition switch on, for about an hour, so we could turn the front wheels to reach each of the strut bolts. I know that was probably a mistake. Since then, I have un-hooked the battery to reset the computer and also verified that I have a good charge. Still no luck. It just turns over really fast and doesn't even try to crank. I'm stuck. Any suggestions?
Thanks!
Ben
Old August 8th, 2007, 09:18 AM   #2
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
sounds like you tripped the theft system that disables it front starting.... you can get it to a dealership and let them reset the computer, but there may be other ways around it
Old August 8th, 2007, 01:04 PM   #3
beheivjer's Avatar
beheivjer is on a distinguished road
If rolls over than it is cranking. are you saying that it rolls over but is not getting spark/fuel ? is the theft light flashing when you get in the car and i mean a fast flash not the normal car is armed flash either? more info would help
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old August 8th, 2007, 04:18 PM   #4
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
yeh...u mean turns over?
Old August 8th, 2007, 04:52 PM   #5
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Sounds like you killed your starter.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old August 11th, 2007, 09:31 AM   #6
The starter works fine, it is turning over fast. It just doesn't start. I checked the fuel pump and I'm getting fuel, just no spark. Someone has suggested the crank position sensor is out. Where is that located. I need to look at the theft system as suggested above. Any other ideas?
Thanks,
Ben
Threads Similar to: HELP! my 99 GT won't start
where to start ?? 96gtponyred 96-98 9 July 22nd, 2007 08:28 PM
5.0 won't start polish95mustang 5.0 Mustangs 15 April 22nd, 2007 11:43 PM
My Car Will Not Start thugsrus777 2.3 Mustangs 14 April 16th, 2007 08:59 PM
no start guesswatidrive V6 Mustangs 3 April 11th, 2007 12:43 AM
Where to start, where to start... LanceD V6 Mustangs 36 March 5th, 2007 02:23 AM
