radiator
how many gallons of 50/50 antifreeze coolant are you suppose to put inside of a 01 mustang
48.47@ 12.58
you should be good with 1 .
I always buy 2 though just incase
#3 | |
2006 Mustang GT
Thats because of all that FAST racing you do, thats always causing your engine to overheat.
I put the whole gallon of the 50/50 mix and the next day i open the cap to the coolant reservoir and it looks like the reservoir is empty. i made sure that everything was tightened and the hose were secure on the radiator and coolant reservoir.
2006 Mustang GT
Did you check for leaks??? Wet spots underneath??? On the ground??? Cracks in the hoses??? Or caps?? Any smells??? Just check everything first, and keep an eye on your temp guage while you let the car run awhile. And be sure to check for leaks & smells while it's running.
Threads Similar to: radiator
| Radiator | V6boi | V6 Mustangs | 12 | October 30th, 2007 02:23 AM |
| Radiator........ | lwhitetrash88l | V6 Mustangs | 42 | July 5th, 2007 10:08 AM |
| radiator | the68stangdude | Classic Mustangs | 4 | July 1st, 2007 03:52 AM |
| V6 radiator? | 95wip | 94-95 | 4 | May 22nd, 2007 12:20 AM |
| radiator | slightly stoopid | 96-98 | 9 | May 17th, 2007 10:57 PM |
