Lts, shortys, stock manifolds? Ported heads comp stage 2s - Forums at Modded Mustangs
post #1 of 16 Old July 19th, 2013, 11:45 PM Thread Starter
liquidhaste's Avatar
Question Lts, shortys, stock manifolds? Ported heads comp stage 2s
I'm still wanting to add more power to my N/A 2v. I have all the basic bolt-ons, plus ported pi heads, and comp stage 2 cams. Im still running the stock exhaust manifolds with an off road x-pipe and weld in flow masters. Should I make the move over to LTs and a shorty ORX? Or perhaps should I address my weld-in flowmasters first. I actually love my exhaust sound currently, so im only talking adding power. I've read shortys don't add much of nothing, but I've also read LTs aren't much better. Anyone got similar mods and dyno'd before and after LTs? Am I losing much with weld-ins? Is it worth 500$ to replace my catbacks with say magnaflow or slp? What would be the first change I should make in you guys opinion? Here's an exhaust clip for my current setup, don't hate on the cracked bumper paint, the car is getting competition orange and blacked out very soon!
liquidhaste is offline
post #2 of 16 Old July 19th, 2013, 11:59 PM
MM's V6 Hater
iTrader: 31 reviews
I wouldn't waste the money on manifolds unless you have a sc
2010 GT500
2013 GT
2012 Dodge Ram 3500
Cabikejumper is offline
post #3 of 16 Old July 20th, 2013, 12:11 AM Thread Starter
Originally Posted by Cabikejumper View Post
I wouldn't waste the money on manifolds unless you have a sc/turbo.
That's sorta what ive been thinking too, what about my catback?
post #4 of 16 Old July 20th, 2013, 04:48 AM
C6Z's & ZL1's are afraid
filmman03's Avatar
now i don't have my stage II heads/cams installed yet, but this is how my car sounds like with full bolt ons.
JBA Shorties
BBK O/R X-Pipe
SLP LM1's
filmman03 is online now
post #5 of 16 Old July 20th, 2013, 07:30 AM
xandraxal's Avatar
I personally have never been a believer in LTs or shorties. For the cost and labor, very little return. And if you go turbo, you'll never need them anyway. I say, if youve already got ported heads and cams, save for FI or go with a nitrous setup if you want power. Have you hit a dyno with your mods now that everythings fixed?
96 GT turbocharged - SOLD
97 Cobra vert stock -SOLD
xandraxal is offline
post #6 of 16 Old July 20th, 2013, 10:31 AM
super serious
phayze's Avatar
I've seen people get decent gains from switching to long tubes, but that's after they've gone FI.
You don't need to get a whole catback to change the sound, just get an offset muffler and have them welded in.
Vortech V3 Si 8 psi
phayze is offline
post #7 of 16 Old July 20th, 2013, 11:22 AM
DJNASTYNATE's Avatar
I just put full exhaust on my supercharged mustang. Headers, off road h and borla stinger catback. Totalling over 1000 bucks, not including the retune. And I only gained 20hp. It sounds a lot better, But it's kinda pricey and a pita to install
2003 Sonic Blue Cobra. TVS, SRA, LT ect ect ect. 605RWHP.
DJNASTYNATE is offline
post #8 of 16 Old July 20th, 2013, 12:14 PM
mrbigjeep's Avatar
and at least half of that was probably from the off road h (if you switched from stock h pipe)
mrbigjeep is offline
post #9 of 16 Old July 20th, 2013, 12:33 PM Thread Starter
Thumbs down
No dyno time logged yet. Very soon, I've been working on suspension recently, I still need to do my control arms and weld in my subframe connectors. Then I'll be hitting the dyno, I'll post it as soon as I go. I'm hoping for 300rwhp. I should hit it, like I said only thing I'm missing is headers. I will be going nitrous for sure. I'd love to get a KB, but that will be at least a year or 2 away, so in the mean time I'll go nitrous for the sake of improved ETs . Hoping to be in the high 12s before spray. More likely be low 13s though.
post #10 of 16 Old July 20th, 2013, 12:37 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
If you want a change in tone the mid pipe will definitely give your car a whole new sound. You will not gain any noticeable difference other then in your head from the new sound. If you were on a larger based block then I would say definitely do headers, but on a 281CI motor its not worth it.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
11.50@121.77@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is offline
post #11 of 16 Old July 20th, 2013, 12:55 PM Thread Starter
Yeah this was never about sound or tone, not sure how this went in that direction. This is about purely power. I'm just wondering if and how much power I'm leaving on the table having welded in flow masters and stock exhaust manifolds. I can do the work myself so the price for LTS and a shorty mid is not really much, bout the same as a full catback , maybe a couple hundred more. Just don't want to waste money if neither will net me much power, with my current setup.
post #12 of 16 Old July 20th, 2013, 01:02 PM
Red07GT's Avatar
On my previous 02 GT I had the Typhoon intake manifold and that was the biggest garbage I ever put on it. It hurt my performance because it being metal, it was super susceptible to heat-soak. I ended up buying the stock plastic ones that Ford uses for about a third of the price of that Typhoon. I just gave the Typoon to the dude that ended up buying that car.
Red07GT is offline
post #13 of 16 Old July 20th, 2013, 01:04 PM
-- Logan --
DGS2vGT's Avatar
the long tubes will actually help because of your ported heads and cam... but you'll probably only experiance 10hp maybe 15hp between full exhaust. But it will sound way better lol.
DGS2vGT is offline
post #14 of 16 Old July 20th, 2013, 05:56 PM
save up for a blower, or turbo instead of longtubes.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, 10 lbs, lee blankenship tune 430/405
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
mustanginky is offline
post #15 of 16 Old July 20th, 2013, 07:20 PM Thread Starter
I'll just go ahead with nitrous for a while, 500-600 isn't going to get me very close to the KB kit I want, zex blackout kit looks good. Probably start out with 100 shot and see if it responds well then might go to 125 shot. I wish I could get the KB 2.1 now Lol those sc are sweet.
post #16 of 16 Old July 20th, 2013, 10:28 PM
US Air Force (retired)
Eagle2000GT's Avatar
If you are already running an off-road pipe then you will not see much gain from headers. Most of the tests I have seen indicate that long-tubes will only get you a couple of horses over shorties. LTs are one of the few mods I regret spending money on. Even supercharged I saw no gains on the dyno.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Eagle2000GT is offline
Human Verification
