Sooo. Honeycomb maf "screen"? - Forums at Modded Mustangs
post #1 of 26 Old July 25th, 2013, 05:31 PM Thread Starter
More average than ever
SlowbaltSS's Avatar
This thing.
Has anyone ever used one? The previous owner of my mach installed a K&N FIPKII. The directions stated to remove the maf screen and leave it out. I was able to fabricate it in as the car ran like crap without it. Like when coming to a stop, the rpms would freak out and bob between like 200 and 800, surly it would die if I didn't have a automatic. The screen fixed this, but I was wondering if there was something better. The honeycomb design is proven to make the airflow more uniform and even if I never feel a difference, I'm all for getting my computer the most accurate readings possible. For $30 that's a small price to pay. Especially since I can see the air being turbulent as hell with this K&N setup.
SlowbaltSS is offline
post #2 of 26 Old July 25th, 2013, 06:23 PM
This space for rent!
speedballin's Avatar
for 30 bucks almost seems worth it just to try it
Current: 04 MACH and 02 Wrangler X (beef'd)
SLP LT, O/R x-pipe, Magnapacks, JLT Cai, TB, MM heavy duty lowers, MM PHB, MGW,FR500s wrapped in Conti DW, 4.30s
speedballin is offline
post #3 of 26 Old July 25th, 2013, 06:47 PM Thread Starter
SlowbaltSS's Avatar
^That's what I'm saying. The only problem is I have no idea where to put it. The way my setup is, I have the filter, then a mounting bracket, then on the side opposite of the filter is the maf housing. There is like no place to put honeycomb thing before the maf where it needs to be. Unless I put it in the maf housing to the point where it will be practically touching the sensor. I'm not sure how effective it will be right there. I'll have to tear into my intake and take a look.
---------- Post added at 05:47 PM ---------- Previous post was at 05:46 PM ----------
From what I hear, the honeycomb setup is popular with the LS crowd.
post #4 of 26 Old July 25th, 2013, 09:29 PM
Well it looks like it is supposed to mount in intake tube? Like slide in and fit snug? If not double sided tape holds everything lol
post #5 of 26 Old July 26th, 2013, 12:33 AM Thread Starter
SlowbaltSS's Avatar
^This is true regarding the tape. Some say it can be welded in. I'll figure something out. And if I by chance get 104938420 RWHP from this I'll be sure to post a write-up on how and where I put it. I'm thinking maybe some gasket maker to give it some grip on the intake "walls", might be a bad idea since some of the maker might break off and get sucked into my intake. It looks like it was more designed for CAIs. I literally have nothing between the filter and the maf other than the mounting bracket that has a hole in it for the airflow. Some bolts go from the maf, through the bracket, and into a metal thing that fits in the opening of the filter. It's going to take all the ghetto-ingenuity I can muster. Busting out the duct tape, double sided scotch tape, and the WD40.
post #6 of 26 Old July 26th, 2013, 09:51 AM
yea man best of luck, take some pics let me know how it goes
to be honest i feel like it will almost do the same thing as a throttle body spacer ( which is kinda nothing) ........butttt...... this is 30 bucks not like 120 lol
post #7 of 26 Old July 26th, 2013, 10:05 AM
me2dumb4college's Avatar
yea and while you're at it, install one of these... Tornado Air :: More Power, More Mileage!
/sarcasm
me2dumb4college is offline
post #8 of 26 Old July 26th, 2013, 10:14 AM
Send a message via AIM to hardhitter
I've used that before on a subaru with good results. You can just shove it in right in front of the maf sensor and it will stay put.
Vortech V2 Si
hardhitter is offline
post #9 of 26 Old July 26th, 2013, 10:22 AM
xandraxal's Avatar
/sarcasm
Lol I had one of those in my old k&n tube hahaha
96 GT turbocharged - SOLD
97 Cobra vert stock -SOLD
xandraxal is offline
post #10 of 26 Old July 26th, 2013, 10:25 AM
jonwrong's Avatar
/sarcasm
Haha. I do actually thing a maf screen for straightening air before entering the maf is helpful for driveability. No power added. Lots of stock mafs have these.
Saleen Series II, MHS Stage 1 Heads & Blower Cams, 365whp/385wtq, Chicane I/C, Mosaleen Pulley, Fidanza FW, Alum Driveshaft, BBK Headers, Steeda Exhaust, TruTrac 31 Spline, 3.55s, 315s, MM FLSCs, Rear LCAs, MGW Shifter, Eibach Pro, Cobra Brakes.
jonwrong is offline
post #11 of 26 Old July 26th, 2013, 10:28 AM
I Poop Entirely Way Too Much
/sarcasm
Not quite the same thing. The honeycomb should certainly settle airflow if its turbulent, the Tornado is makin more turbulent air flow...
Nothing says "were dating" like sticking your dick in her.
03_StangGuy is offline
post #12 of 26 Old July 26th, 2013, 10:35 AM
/sarcasm
dudde i bet it gives the same power as a turbo for less it probably even whistles
id rather have the sound of a baseball card in my spokes it added more poewer
post #13 of 26 Old July 26th, 2013, 11:19 AM
All maf screens, inserts and misc air flow straighteners should ALWAYS be mounted directly in front of the maf. If you mount it way upstream of the maf it wont do any good at all.
Honestly the whole honeycomb is not something i will run. They are extremely restrictive when compared to a maf screen and are a bandaid for an improperly located maf.
1999 GT 630rwhp on pump, TFS Heads, MMR 4.75L, Highly Modified Kenne Bell 2.1 @ 20lbs, Custom Intercooler, JLT High Boost CAI, CMS Custom TFS Specific Cams, 3.55s, MGW, T56
Nitmare67 is offline
post #14 of 26 Old July 26th, 2013, 11:28 AM
I smell like beef
Shelbydog!'s Avatar
iTrader: 11 reviews
I haven't ran a maf screen since i put the blower on, is that bad?
4r70w Dirty 3800 Stall P1SC@9lbs TRV25 60# SVT Pump FRPP 4.10s TFS TB+Plenum MAC O/R H Flows 382rwhp 384rwtq
Shelbydog! is offline
post #15 of 26 Old July 26th, 2013, 11:32 AM
Just don't have the MAF on a bend
---------- Post added at 11:32 AM ---------- Previous post was at 11:31 AM ----------
i was debating on a catch can...
post #16 of 26 Old July 26th, 2013, 11:37 AM
I smell like beef
Shelbydog!'s Avatar
iTrader: 11 reviews
I'm only running an air oil separator
post #17 of 26 Old July 26th, 2013, 01:03 PM
yea, I really need to get one... which one are you using?
sry for thread jack
post #18 of 26 Old July 26th, 2013, 01:37 PM
I smell like beef
Shelbydog!'s Avatar
iTrader: 11 reviews
sry for thread jack
Jegs brand. I'm venting to atmosphere now so I guess it doesn't really do its job anymore.
post #19 of 26 Old July 26th, 2013, 02:07 PM
jonwrong's Avatar
sry for thread jack
I had a catch can I purchased, and it did not catch anything. I ended up making one with an ebay catch can (like $30). I used this guy's method:
DIY Oil Catch Can - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
The stainless steel mesh can be bought at Home Depot in the house cleaning section (pot scrubbers). My catch can now works very well.
jonwrong is offline
post #20 of 26 Old July 26th, 2013, 02:57 PM
Need even room after the bend for the airflow to even out too.
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/308754-sooo-honeycomb-maf-screen.html
Thread Halltech MAF Screen C6 | Corvette C6 - C1 Reviews, Performance, Parts for Sale | BoardReader This thread Refback December 9th, 2013 09:12 AM
