NX Plate system hick-up
OK i finally got off my but to get the nitrous going, the set up is the NX 4.6 plate kit (50 shot to start)car has the K&N FIPK and just some DynoMax muffs and an SCT x-cal with a Nitrous tune. At 3K i ingauge the system and right at the begining there is a slight almost bog or miss then it catches its self and runs great. Any thoughts to this and if so any fixes
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
get some ngk step colder plugs and gap em at 35 i think it was i did mine..and use some octane booster from advance everyonce in a while it helps..
i have 2 step colder ngk plugs and i don't think its an octane problem but more of a delievery problem
never had my own n20 setup but been around them...... does the car black smoke when it bogs... maybe a delay in the n20 solenoid low voltage bad ground etc..
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
purge??? may not be shooting liquid at first. i have a nos system with a n/x plate set up shooting 125. only need 1 stage colder plugs with a 50shot. dont even need a tune to run a 50 shot, you will once you go to a 100 shot. 125 and over will need 2 stage colder plugs, tune, and a fuel pump highly recommended.
well i ran it at night so the smoke i cant see, but voltage to the noids could be the culprit i'll check to day and see what turns up
Cigar Assassin
i agree with sweet. do you have a purge on the system?? nitrous tends to dissapate as it sits in the lines so when you first spray it is just air and then the nitrous hits
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox ![]() |
i've got a purge but its not hooked up so thats gonna happen today as well and that could verywell be the case but i ran it twice and it happened twice, could the system be spiking lean for that little bit?
Cigar Assassin
couldn't tell you that one brah. i have the same kit on my car with a hundred shot. I purge and as soon as I hit 3000 RPM, I get a kick in the ass from the nitrous hittin
how are you getting fuel to the niod?
pulled a plug and the boot has cracked and the plug is white good thing i havent run it much
Threads Similar to: NX Plate system hick-up
| Traction Control System (TCS) and Anti-Lock Braking System | WAR-PARTY | 99-04 | 14 | May 1st, 2011 02:17 PM |
| nitrous express plate system | Modern_Muscle | 2005 - 2010 | 6 | September 26th, 2007 12:35 AM |
| NX 2v Plate Kit | TheBusher | 99-04 | 24 | September 8th, 2007 04:33 AM |
| Traction Control System (TCS) and Anti-Lock Braking System | WAR-PARTY | 99-04 | 11 | June 18th, 2007 07:56 PM |
| Cold Air Intake System/Shaker System | Bish | Audio/Video | 11 | June 15th, 2007 11:04 PM |
