13.400 @ 110 WTF?
Old August 12th, 2007, 11:41 AM   #1
BoostHard1210's Avatar
13.000
BoostHard1210 is on a distinguished road
13.400 @ 110 WTF?
Went to the track last night and ran a best of 13.4 with lots of mods what am i doing wrong? 1st gear and 2nd burn out to much also i have a set of 3.73s that might go on but shouldnt i run 12s atleast with 10 pounds of boost? any info thanks
Abe
Old August 12th, 2007, 11:43 AM   #2
energiesource's Avatar
energiesource is on a distinguished road
well the burnout could have caused that, i mean after all, it is precious fractions of a second that youre losing, work on your launch and you should be good
what do you have done to the car
Old August 12th, 2007, 11:49 AM   #3
13.000
i have a procharger 10 psi msd ignition stage 2 clutch 70 mm t body plenum intake manifold powerpipe intercooler subframes catted x pipe flowmasters. i would even take off at 2000 rpms to not spin then i would floor it and go into a spin 1st and 2nd would get kinda sideways
Abe
Old August 12th, 2007, 11:51 AM   #4
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
You need better suspension, what tires are you running on? Is the car dyno'd? What kind of numbers are you putting out?
2004 GT Boosted by Vortech
Old August 12th, 2007, 11:53 AM   #5
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
He mentioned everything but tires...
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old August 12th, 2007, 11:53 AM   #6
13.000
i have yokohama 275-40-17. im gona get it dynod this week.
Abe
Old August 12th, 2007, 11:54 AM   #7
04GTAMPA's Avatar
Problem #1. Get some real drags.
Old August 12th, 2007, 11:55 AM   #8
13.000
could i put slicks on my 17 inch rims??
Abe
Old August 12th, 2007, 11:56 AM   #9
Garhfer's Avatar
If you want to run slicks you better beef up your rearend and torque boxes...
Old August 12th, 2007, 11:58 AM   #10
13.000
whats torque boxes? how would i beef up the rear end?
Abe
Old August 12th, 2007, 12:03 PM   #11
Garhfer's Avatar
get 31 spline axles, and you'd need a 31 spline diff to run those, torque boxes you need to have them welded in (they're where your control arms connect to the body of the car in the rear), they sell battle box kits that reinforces them from the inside too to further strengthen them.
Old August 12th, 2007, 12:06 PM   #12
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
31 Spline Axles
31 Spline Diff
3 inch lug studs
Battle Boxes (like said above)
Tubular Upper and Lower Control Arms
Mickey Thompson ET Streets (drag radials)
Remove Rear Sway Bar
And there ya go...You will be ready for some low 12's maybe even 11's...
Facebook
Google+
Old August 12th, 2007, 12:10 PM   #13
13.000
110 mph is that high for a 13? thanks for info guys
Abe
Old August 12th, 2007, 12:11 PM   #14
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
That 110 means you were spinning your ass off...
You should at least have 12's in the car...
Facebook
Google+
Old August 12th, 2007, 12:11 PM   #15
Garhfer's Avatar
uhh, I ran a 13.5 with 115mph slipping and sliding all over the track... lol
Old August 12th, 2007, 12:15 PM   #16
13.000
that sucks specialy when your runin against a gto and your sideways while hes laughing down the track
Abe
Old August 12th, 2007, 12:15 PM   #17
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
When you spin it makes you MPH go crazy high...
Theres 12's in the car at least...
Facebook
Google+
Old August 12th, 2007, 12:15 PM   #18
13.000
where can i find the torque box stuff?
Abe
Old August 12th, 2007, 12:17 PM   #19
13.000
Originally Posted by ChrisJ
31 Spline Axles
31 Spline Diff
3 inch lug studs
What does removeing the rear sway bar do?
Abe
Old August 12th, 2007, 12:18 PM   #20
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
Clicky
Facebook
Google+
