Best forged rotating assembly to buy? - Forums at Modded Mustangs
post #1 of 33 Old August 2nd, 2013, 03:21 PM Thread Starter
Ok guys.. So my last trip the track I messed up to pistons, so I'm looking to buy a new forged rotating assembly and reuse my stock block and I have thought about using my stock crank.. Just wanted to see what company you guys think I should go with.. I will be spraying the car with a 150 shot when I get it back together, so I need to know what cc pistons would work best.. I also will be upgrading my fuel system as well..
02 Mustang GT
Mac Longtubes,lethal xpipe,BBK 78mm TB&plenum,PP intake,JLT cold air,4.10 gear,Zex(125)shot,Sportline springs,subframes.. Tuned by Redline Performance in Asheville,NC
446hp 570tq
Best 1/8 7.81@91 1.65 60ft
True Blue 02 is offline
post #2 of 33 Old August 2nd, 2013, 04:23 PM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
I shot you over a PM
853rwhp @ 23psi
75mm Turbo 5.4 swap E85
#turbo2v
10.11 @ 138mph STOCK LONGBLOCK
9.11 @ 149mph - New Longblock /w Powerglide
www.JPCracing.com 410-729-0005 ext. 11
PM me if you need any parts or advice!
sharkbait is offline
post #3 of 33 Old August 2nd, 2013, 04:30 PM Thread Starter
Pm sent.. Thanks again
02 Mustang GT
446hp 570tq
post #4 of 33 Old August 2nd, 2013, 04:40 PM
Froush's Avatar
iTrader: 8 reviews
If you are building the engine, i would at least find a forged cobra crank to slap in it. The stock crank is good for a little bit of power, but i personally wouldnt take it pass 550ish. Rods are the weak point. Then obviously, get some arp main studs (i have some used for sale if youre interested)
"Happiness is being blown and stroked at the same time"
V6 => Teksid 302 stroker 644hp/576tq.
Caitlyn Jenner build underway
My Build Thread click link
http://www.moddedmustangs.com/forums...shs-build.html
Froush is offline
post #5 of 33 Old August 2nd, 2013, 05:20 PM Thread Starter
Thanks for the info.. It will be a few months before I can buy anything, I was just trying to figure out what would be my best options
02 Mustang GT
446hp 570tq
post #6 of 33 Old August 2nd, 2013, 06:56 PM
Lexus FTW
02GTAUTO's Avatar
Should buy mine
I went with MMR rods and manley pistons. Havn't had any time on them so done know how they really are but price was decent and I had good luck with MMR
02GTAUTO is offline
post #7 of 33 Old August 2nd, 2013, 08:31 PM Thread Starter
I have heard good and bad things about mmr but mostly on there shortblocks
02 Mustang GT
446hp 570tq
post #8 of 33 Old August 2nd, 2013, 08:38 PM
Froush's Avatar
iTrader: 8 reviews
Yeah, its normally their shortblocks or customer service. A while back, their oil pump gears were shitty but i think they fixed that. Usually, their parts are pretty good though
Froush is offline
post #9 of 33 Old August 2nd, 2013, 08:41 PM Thread Starter
I've looked at their rotating assembly's.. Not to bad on price
02 Mustang GT
446hp 570tq
post #10 of 33 Old August 2nd, 2013, 10:58 PM
JD mustang's Avatar
SO what happened at the track. To much power on stock internals. Im going next week to get a dyno tune for 125 zex shot. Got me nervous
Stock GT500 for now. J&M lca
JD mustang is offline
post #11 of 33 Old August 3rd, 2013, 09:57 AM Thread Starter
Don't worry you will be fine on the 125 shot.. I added the 150 jets and that's how it happen.
02 Mustang GT
446hp 570tq
post #12 of 33 Old August 3rd, 2013, 01:08 PM
02TrickFlowGT's Avatar
Im doing a DSS 5.0 stroker rotating assembly in a cobra block, rated to 1000hp, Figures that should be enough for 15 psi (+/-) and a 200 wet
Built, Forged, 5litre, Turbo cams, Turbo comming soon!
02TrickFlowGT is offline
post #13 of 33 Old August 3rd, 2013, 01:40 PM Thread Starter
Should be a solid setup..
02 Mustang GT
446hp 570tq
post #14 of 33 Old August 3rd, 2013, 01:47 PM
got the upgraded crank too hopefuly that should be goo, iv been looking into rotating assemblys for a long time now and im back where I started with this DSS, got a steal on it so I couldnt let it go, ill let you know how it holds up, you made up your mind in full yet OP on what you want to do?
post #15 of 33 Old August 3rd, 2013, 02:05 PM Thread Starter
No not yet I'm still looking what's out there.. Definetly let me know how it holds up
02 Mustang GT
446hp 570tq
post #16 of 33 Old August 3rd, 2013, 02:34 PM
04redGT's Avatar
These guys have given you some decent suggestions. But, if that is all you are gonna spray, I would honestly only replace the pistons and rods. The crank will hold up just fine. Summit has some decent pistons and rods to choose from. Stock compression is just fine, so a piston with a similar dish is good.
I think I want a turbo, oops I mean Supercharger!
298/323 on motor with MHS Nitrous Stage 1's
403/490 on a 48 Jet
Tuned by Unleashed Tuning
04redGT is offline
post #17 of 33 Old August 3rd, 2013, 02:40 PM Thread Starter
Thanks for the info 04redgt if I decided to bump it up to a 200-250 shot would I need to replace the crank as well?
02 Mustang GT
446hp 570tq
post #18 of 33 Old August 3rd, 2013, 02:49 PM
04redGT's Avatar
The cranks are stronger than what some think. To give you an idea, nmra racers use them in their 9k rpm motors! I would be willing to take one to 600hp, but I don't abuse my stuff like some people and I would only subject it to that at the track.
403/490 on a 48 Jet
04redGT is offline
post #19 of 33 Old August 3rd, 2013, 02:58 PM
cranks good to 600 (+/-) soo if your going to be making that or more on the bottle id do it, or if you have plans for other power increasing mods down the road go ahead and do it while your there, Cobra crank can be had for 350ish
post #20 of 33 Old August 3rd, 2013, 03:04 PM Thread Starter
Thanks for the info guys.. I would only be running hard on the street I don't do any street racing
02 Mustang GT
446hp 570tq
Human Verification
