99 stang surges when put in gear, or with ac on
Old August 13th, 2007, 07:33 PM   #1
dobermean's Avatar
dobermean is on a distinguished road
help, i have a 99 mustang gt with a sc, auto trans, when you put it in gear, surges big time. it seems to be alot worse with ac on. no vacuum leaks found, changed idle control valve, running out of options.
Old August 13th, 2007, 07:40 PM   #2
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
hmmm. try checkin ur underdrive pullies
Old August 13th, 2007, 07:47 PM   #3
dobermean's Avatar
first time i heard that one...........what could be wrong with them?
Old August 13th, 2007, 07:48 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
what kind of sc?
do you have a tune?
Old August 13th, 2007, 07:55 PM   #5
dobermean's Avatar
vortech v2 sq, with the tune they sent me, since then i took off the sc, took everything back to stock, but still does it, just not as bad as with the sc.
Old August 16th, 2007, 01:00 PM   #6
jblood37 is on a distinguished road
I've had the same problem a few times with with 2000 model gt. It scared the shit out of me a few times, I've almost hit people at the gas pumps. I don't know what causes it either, and mine doesn't do it as much anymore.
Old August 16th, 2007, 01:45 PM   #7
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
Ok, few things. First, the tune they send sucks!
When did it start? anything done to the car before it started?
have you checked your pcv valve? My father's Grand Marquis was doing that crap and it went away when I changed the PCV valve.
Checked the timing sensors?
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old August 16th, 2007, 06:30 PM   #8
dobermean's Avatar
it used to do it once in a great while just a little when i first got the car, but with sc on its big time.only thing on it is cat back exhaust and i had ud pulleys on it but took them off with the sc..........ive changed the pcv valve, and how do you check the timing sensors? thanks
Threads Similar to: 99 stang surges when put in gear, or with ac on
gear ratios in an 07 stang innrkid 2005 - 2010 15 May 22nd, 2007 12:38 AM
Stang vs Stang at Moroso ShawnyB Drag 0 May 7th, 2007 04:21 PM
4.30 Gear to much gear for street use/daily driver? Bigb2000GT 99-04 10 March 28th, 2007 05:22 PM
94 ford mustang surges at idle and cuts out when push gas akahoops 5.0 Mustangs 5 February 18th, 2007 02:31 PM
Engine surges at start and idle fluctuates 200KMILES V6 Mustangs 2 May 3rd, 2006 05:23 PM
