cooling problems - Page 2
Old August 15th, 2007, 08:51 PM   #21
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ do it!
be the test dummy
Old August 15th, 2007, 10:41 PM   #22
Blackblurr_00GT's Avatar
Y2K GT
13.3@103
Blackblurr_00GT is on a distinguished road
Originally Posted by RyanGT
Does the royal purple "purple ice" coolant actually help lower temperatures like it says?
http://rpmoutlet.com/newv8cnltf.htm#6
or is it just another anti freeze
i dont know to much about the RP but the redline water wetter does work i could actually se the temp gauge reading lower after i put it in.
you could try that
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature.
Old August 15th, 2007, 10:47 PM   #23
mattstang's Avatar
mattstang will become famous soon enoughmattstang will become famous soon enough
Send a message via AIM to mattstang
is it heating up on the road in stop and go maybe switch to a pusher fan??? we used to do it on the 4x4s
Old August 15th, 2007, 10:50 PM   #24
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
What is a pusher fan? I've only heard of a flex fan, a clutch fan and an electric fan...
2004 GT Boosted by Vortech
Old August 15th, 2007, 10:52 PM   #25
mattstang's Avatar
fan on the inside that blows the hot air out or take a regular fan and put it on the outside
Old August 15th, 2007, 11:10 PM   #26
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
Try the new purple Ice and when was the last time you flushed the system?
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old August 15th, 2007, 11:16 PM   #27
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Brand new block has 400 miles on it. It actually has an exhaust problem the driver side heats up double than the left, and visably shakes (and rattles a little) So i think that is what is causing under hood tempatures to be way above normal. The actual block temp seems normal. But i am going to switch the ud water pump pulley to stock (thanks doc) and go to a 160 degree thermostat.
Ill try that royal purple too might as well. With the pulley and thermostat i think it will lower the temp a bit till i can fix the exhaust. I have a new clutch coming so exhaust will have to come down anyways.
Old August 15th, 2007, 11:44 PM   #28
04GTAMPA's Avatar
My car has the same problem. In fact, is one the hottest running cars I've seen. It has a major exhaust leak from the driver's side header that heats up all the way through the firewall into my feet! That is driving me crazy.
Old August 15th, 2007, 11:50 PM   #29
mattstang's Avatar
my pass floorboard gets hot i looked at the exhaust and the back cat is leaking the dealer paid some fool a quarter to weld it on by the it looks but is that normal for the floor to heat up
Old August 15th, 2007, 11:52 PM   #30
04GTAMPA's Avatar
nah, my long tubes are probably leaking from the EGR connect... We just did the gaskets two weeks ago with the heads, well AC did. I can't take any credit for that.
Old August 16th, 2007, 07:42 PM   #31
2000 GT
Anybody have any other ideas? Would doing something like putting heat resistant plastic wrap (one comes with kenne bell kit for the radiator hose) on both the intercooler hosing and the other radiator hose?
Im putting the water pump pulley and 160 thermostat on it tomorrow. And see if the auto parts store has some sort of lower temp coolant, like purple ice.
Threads Similar to: cooling problems
Cooling problems suburban_concepts 5.0 Mustangs 9 October 21st, 2007 11:14 PM
Cooling Fan Stangzilla 5.0 Mustangs 23 March 25th, 2007 10:15 AM
Radiator Cooling Fan Problems jagstang96 96-98 1 October 15th, 2006 05:05 PM
Cooling Fan Problems rene9 96-98 6 September 26th, 2006 06:29 PM
