2000 GT
cooling problems
Well, what can i do to get the engine bay cooler? I mean its running pretty damn hot enough to start damaging hoses (heat resistant hoses). I have the 180 degree thermo and a stalker 2 functional ram air. What else can be done? Better fan? or maybe a different setup on the hood for more circulation?
The damn KB is making too much heat! |
intercooler?
2000 GT
Hooked up and running. Full of coolant. It wasnt this hot the first time around but i have a road trip at the end of the week and driving 1500 miles scares me with it acting like its going to burn hoses. already has discoloring on hoses and some are starting to soften (breather hoses)
ever consider a snow kit?
2000 GT
never even heard of it? link?
2000 GT
thats interesting! How often would it need to be refilled though?
this what I got from them:
8. How long does the fluid last? The range you'll get out of our system depends on a couple of variables: - How much power you're making - The settings of your system - How aggressively you drive In most instances our standard 2 quart reservoir works well to provide the required amount of fluid. We have seen that a 2 quart reservoir provides enough fluid for a 400-500 hp car to make 12-15 full throttle quarter mile passes. For those looking to get more range out of their system, they can tap into their factory windshield washer reservoir and use it to hold water/methanol. This is a good option because most washer reservoirs have a large capacity (normally at least a gallon) plus they're already methanol resistant (washer fluid has methanol in it). Also, the washer reservoir is already under the hood so it doesn't require having to add another bulky item into the engine bay. The fitting needed to tap into your washer reservoir is available for $9.95. The standard 2 quart reservoir can be swapped out for a blukhead fitting at no cost.
2000 GT
would be a pain to fill that every morning haha. Although i think it might be worth to try when i get more funds.
Anything else you can think of that could help? Upgraded radiator fan maybe? |
they also make things you can pour in your tank and it cools the boost.
like "water wetter" just upgrade to a 4 core and you will have no issues
2000 GT
Hmm i used to have underdrive pulleys and i had to change the crank to stock because it was screwing with the supercharger... And i didnt do the underdrive pulleys the owner before me did, so i dont have stock ones. Would that be making the water pump working at sub par?
def.
your not supposed to run ud's with a blower. it can be done obviously though.
Bad thing about a meth kit on a twin screw is you spray it through the blower.. and yea, no UD pullies with a blower
2000 GT
Having trouble finding the stock ones... anywhere.... have a site? Its easy to find UD though!
One Man Wolf Pack
trade with someone. I sure somebody would trade their stockers for UD's
![]() ΜΟΛΩΝ ΛΑΒΕ
One, If you need a stock water pump pully I'll send you the one I bought to put on mine for $20 bucks. Two, Kenne Bell sends the blower with a 160 thermastat in it, did you change it out?
Edit* I'm sitting at work and not lookin at the site too often. If you want the pully you can email me at my work email christopher.neiss@usmc.mil
Mustangless atm 2006 2500 HD Diesel. Built allison trans and other goodies
2000 GT
The mechanic did that put in my block from vt. I thought a 160 would throw codes or so i heard? Well damn! Can the tuner turn off specific codes? I have diablo.
2000 GT
Does the royal purple "purple ice" coolant actually help lower temperatures like it says?
http://rpmoutlet.com/newv8cnltf.htm#6 or is it just another anti freeze |
I haven't heard of that specifically but everyone tends to rave over RP.
2000 GT
haha thats what i was thinking. So figured someone has tried it
Threads Similar to: cooling problems
| Cooling problems | suburban_concepts | 5.0 Mustangs | 9 | October 22nd, 2007 12:14 AM |
| Cooling Fan | Stangzilla | 5.0 Mustangs | 23 | March 25th, 2007 11:15 AM |
| Radiator Cooling Fan Problems | jagstang96 | 96-98 | 1 | October 15th, 2006 06:05 PM |
| Cooling Fan Problems | rene9 | 96-98 | 6 | September 26th, 2006 07:29 PM |
