Discussing TKO Conversion in the 99-04 Forum. Sooo... anyone know what is needed, or have any links to what I would need ...
Old August 18th, 2007, 08:09 PM   #1
2002 Chevrolet Impala
TKO Conversion
Sooo... anyone know what is needed, or have any links to what I would need to convert to a TKO tranny??? Also, is the TKO that much better then the T56 or TR6060?
Old August 18th, 2007, 10:03 PM   #2
SWEET2KSTANG's Avatar
2000 mustang gt
12.01@114.69
the tko is a very stout trans. the t56 is only rated to around 450 (conservative ratings). install would be, bell housing, spacer, cross member, clutch kit if you go to a 26 spline input, shifter, i believe crossmember and length of driveshaft.
stock long block, bolt ons, slicks, and a little squeeze
1/4 E.T. 12.06@114.69
Only two defining forces have ever offered to die for you:
1. Jesus Christ
2. The American G. I.
One died for your soul, the other for your freedom.
Old August 18th, 2007, 10:07 PM   #3
Garhfer's Avatar
2004 Mustang GT Conv.
Here's some information I've found on the tr6060:
So you might be wondering exactly how a Tremec TR-6060 compares with the T56 you know and love. In short, it's better in just about every way. It can handle more torque thanks to a move from a 10-spline input shaft to a 26-spline unit. Moreover, the new case is stronger, the countershafts are one-piece units, and the gear faces are wider. All these changes add up to much greater strength, which we'll all appreciate after we start modding these cars. What we noticed while driving the car, however, was its easy, precise shifting despite the factory shifter.
The prime movers in the better shifting are increased synchronizers on all the gears. Where the Terminator T56 had only two synchros on the 1-2 and 3-4 shifts and single synchros on the remaining gears, the TR-6060 offers triple synchros on the 1-2 and 3-4, and dual synchros on all remaining gears, including Reverse. Plus, the synchronizers have been upgraded from a carbon-particle paper to a sintered-bronze material.
A larger input shaft, beefier gears, more synchronizers, closer gear ratios, and more make this six-speed one that should become a popular aftermarket upgrade.
So this transmission shifts easier, but it also offers a shorter shift throw. "The synchronizer hubs are much narrower, reducing fore and aft shift travel," Tremec's Jim Averill explained. "Additionally, the hub system uses three encapsulated ball-and-coil-spring struts that are much more precise than the old-style hoop-and-stamped strut. This also adds to a smoother fore, aft shift."
2004 GT Boosted by Vortech
Old August 18th, 2007, 10:26 PM   #4
energiesource's Avatar
ohhh 6060 i was thinking of the 600, my bad
2000 Mustang GT, Steeda Triax shifter, Underdrive pulleys, SLP LM2, MAC L/T and O/R H-pipe.
Transmission fix, new clutch
Coming soon: Brakes.
Old August 18th, 2007, 10:42 PM   #5
AssHole Admin
Drgnracin72's Avatar
2000 mustang GT
11.79@125
remember also, tko dont like to be shifted above 6000 rpms. a lot of people dont like them in street cars and even some racers who have them say its to difficult. it does hold a ton of power, but has problems going to the next gear above 6000 rpms
if i had a cobra R, i'd take out the vents and put little miniature fish tanks in their places and fill them with sea monkeys
McCain/Palin 08
Old August 18th, 2007, 10:50 PM   #6
so then is there any other alternative? i mean tkos are the best tremec gets pretty much, maybe aside from a t56 with viper specs
Old August 18th, 2007, 10:53 PM   #7
2000 mustang gt
12.01@114.69
the guys at promotion powertrain are saying that their tko's arent like that. they go in and fix whatever causes that.
1. Jesus Christ
Old August 18th, 2007, 10:55 PM   #8
AssHole Admin
2000 mustang GT
11.79@125
well cool, if they do then get one. that is the only draw back to the tko, other than that its a badass tranny
McCain/Palin 08
Old August 19th, 2007, 02:36 PM   #9
superbeef1000's Avatar
check this site http://www.modularmustangracing.com/...rans_drive.htm
Old August 19th, 2007, 02:55 PM   #10
i know its off topic but i was looking at the short and longblocks on this site, and is it better to buy a short block or a long block, it seems like they rip you off when it comes to the longblock, or would it end up costing more to add all the stuff yourself onto a shortblock?
Threads Similar to: TKO Conversion
2v to 3v conversion??? droppedbass87 96-98 22 November 2nd, 2007 12:36 PM
conversion Mustang RacR94 99-04 8 April 2nd, 2007 11:02 PM
2.3L to 5.0L conversion stan_doe 5.0 Mustangs 6 January 23rd, 2007 01:39 AM
99-04 V6 To GT Conversion ?'s ineedajob V6 Mustangs 7 November 9th, 2006 04:18 PM
After A 5 Lug Conversion... 347tt 5.0 Mustangs 7 September 28th, 2006 03:53 PM
