Procharger & MAF???
Just curious... all the pics of the Procharger setups i've seen only show an air filter, then inlet tube, then it goes straight into the supercharger... just wondering, does theprocharger kit come with a MAF delete or something? Does it relocate it? If so where? And alos does it need to be upgraded with it? Thanks in advance...
-SEMPER FI- |
its still there, its just in the intaek tract in the inlet pipes instead of before the supercharger
So it's on the hot side/ in between the superchrger and the throttle body??? Can the stock MAF handle the boost?
-SEMPER FI- |
yeah, what do you want the maf to read? you want it to read the air coming into the supercharger or after the supercharger puts it out? if your reading the air coming into the blower, your not getting a true air reading, becasue oince it goes through the blower, there is a shit ton more air.
yeah they can handle it just fine
Yeah... just didn't know. On my nissan and my GTI the MAF was before the turbo on the turbo inlet pipe, so, i wasn't too sure if it was the same kinda setup with a centri or not.
-SEMPER FI- |
Anyone else with a procharger???
-SEMPER FI- |
Its in the fender. Im running a 90mm Lightning MAF on mine.
in the fender? before or after the intercooler?
-SEMPER FI- |
Anyone have any pictures of thier install?
-SEMPER FI- |
Here is a customer of mines car using the ProM ATI blow through meter
2003 Cobra 9.5 @ 146 on radials Just a few bolt ons with a good tune 04 Mach1 9.78 @ 138.9 |
its after the intercooler.
thatnks alot.... that helps alot. Do the blowthrough ATI's use the factory harness and connections, or is an aftermarker one needed w/ a MAF translater?
-SEMPER FI- |
It used the fatory harness, but I did have to splice in a temp. sensor. They built the temp sensor in the factory MAF on 02+ Stangs and the earlier models had it plugged into the intake pipe.
i got an '01.... so i shouldn't have to do any splicing?
-SEMPER FI- |
Threads Similar to: Procharger & MAF???
| Procharger | flattusmaximus78 | V6 Mustangs | 37 | August 24th, 2007 07:22 PM |
| procharger help | BoostHard1210 | 99-04 | 14 | February 23rd, 2007 12:41 AM |
| new procharger 99-04 | scubasteve041186 | V6 Mustangs | 7 | February 18th, 2007 02:34 PM |
| procharger f1a | Drgnracin72 | General Tech | 8 | April 15th, 2006 02:01 AM |
