the plan is forming.
Old August 21st, 2007, 06:23 PM   #1
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
well i've been doing some research and i think i am just going to scrap the terminator idea and build my GT.
first things first, i want to go with a new shortblock. i am thinking a 302 stroker forged shortblock. i will keep my old shorblock and leave it alone so if/when i want to resell my car for some reason i will still have the original engine.
i will run my stock heads and intake, but probably go with an accufab plenum/tb combo.
now the big part, i want to go with a twin turbo setup. i've been looking at the HP twin turbo kit and it looks pretty nice. it includes a coilover conversion and tubular K-member setup. i have also seen the hellion single turbo setup but i want to go with twins.
once i get all that accomplished, (we're looking at over 10K so far) i should have my new setup up and running. i will run a conservative boost and tune until i can save up to get my transmission and rear end built to handle the power, + brakes to stop better, then once i can afford to do all that i will crank the boost and the forged stroker block should handle some serious power. and if that just isn't enough for me i can get some heads and cams.
i know this is a pretty far fetched idea, but i have already saved up over 1K just for my car and i'm continuing to add to it whenever i get a little extra cash.
any input would be cool, this is going to be a good 3 year project. once i get out of college i'll really be able to go to work on it because school takes a good chunk of my budget away..
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old August 21st, 2007, 06:38 PM   #2
HessiaN257's Avatar
13.9@101
HessiaN257 is on a distinguished road
Its a good plan. But I don't know how practical it is for a budget project. You will most likely be spending more money then you want to on supporting mods and other stuff.
But the outcome will probably come out sweet.
13.9@101 before some mods
Old August 21st, 2007, 10:08 PM   #3
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
I would put the extra money from the stroker into some good heads and just build a stock stroke shortblock. You really wouldn't want the stroker block with the turbo IMO, because you will need the upper rpm revs for that TT to really spin up and the stroke of the 302 could cause some unwanted stress.
Old August 22nd, 2007, 12:21 AM   #4
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
ok thats interesting, i didn't know that. i've been doing a lot of research on mustangs and i have learned a lot but there is still much about mods that i do not know.
Old August 22nd, 2007, 12:25 AM   #5
Proud American
MustangMatt96GT's Avatar
I agree!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old August 22nd, 2007, 12:46 AM   #6
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
a correctly built stroker kit will be able to rev just as high. but i do agree, just bore +.020 or whatever you need and invest into heads and cams. heads and cams are a big key when it comes to making power. without flow, or the correct cams the engine is limited on it potential. the 8.8 will handle the power you want to put to it, just weld the tubes and get good internals. transmissions options will be the tko and the viper spec t56 to handle that much power.
Threads Similar to: the plan is forming.
So, Here's The Plan Danedog311 2.3 Mustangs 26 January 29th, 2008 07:12 PM
The PLan scxc15 V6 Mustangs 17 March 22nd, 2007 01:39 AM
Plan on getting t-lock Orangester V6 Mustangs 5 January 12th, 2007 01:03 AM
My New Plan xx9gt6xx 96-98 10 November 17th, 2006 07:12 PM
new plan for scrap jr. scrapdaddy jr. V6 Mustangs 1 September 9th, 2006 12:52 PM
