Discussing will i need bigger injectors? in the 99-04 Forum. Just searched and couldnt really find anything that would help me... Anyways my setup is ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2000 GT
Just searched and couldnt really find anything that would help me... Anyways my setup is a kb 9psi kit running at 11psi at high rpm. 75mm tb, 90mm mass air, stage 2 blower cams, boost a pump, on a vt built bottom end. Rest of the mods in the garage. Will 36# injectors work or should i bump up to 42#?
Going to the tuner Monday and would like to not run out of fuel and have to get parts and pay for another tune. Also i might be bumping the pulley up to a 14psi pulley in the future would i need it then? |
SoMuchCoolerThanChiaGutt
12.88 @ 112
i would say better safe than sorry. especially if you are thinking of bumping up to 14 lbs later on.
Have a WHITE99 kind of day. www.myspace.com/gtsetgo www.myspace.com/philfriedman www.myspace.com/robsidea A hard-on doesn't count as personal growth. |
91 Sonic Blue Goodness
19.83 @ 12mph
bump to 42's .. why not?
MM's Mad Scientist
2003 GT
Street Fast 16.9@76MPH
I would think you could get away with 32's- which might be easier on your idle setting, but the 42's should def. accomodate your needs.
I'd say set up to the 42's. Your gunna be right around the 500rwhp + with 9psi (i'm assuming) witch is pushing it for the 36ers.
Mustangless atm 2006 2500 HD Diesel. Built allison trans and other goodies
2000 GT
k so 42's it is! Should i get them from americanmuscle.com? Or somewhere else?
Ford Racing through Summit $399 for 42 #ers
Says ending year 1998 but they will work every where I look says its the same 89-04 But call summit to ask first. http://store.summitracing.com/partde...5&autoview=sku
2000 GT
awesome thanks guys! Will post numbers soon going to dyno monday.
I'm going to make a guess. with the 9 psi pulley I'll say you'll hit 536 rwhp. if you up it to the 14 psi pulley I'd guess you'll scare 630 rwhp.
Let us know what he gets!
2001 YUGO GT
I think that 36lbs should be fine to start with. I have a 2.6 and KB sent me 36lb injectors. I bumped up to 72. A good gouge is found on the RPM outlet page as to how to figer out what sixe you need, than bump it up one. Make sure you have both an air/fuel mixture gauge and an EGT gauge. another gauge that is essential is a fuel pressure gauge. I might be preaching to the court. But for what it's worth.
![]() Military Crew Golden Shellback U.S. Navy ret. Been around the world 17 times, seen everything from a Cat fornicating contest to an elephant jack off. When Jesus has a question God tells him 'Go ask the Chief.' |
Threads Similar to: will i need bigger injectors?
| WTB: Injectors for 04 GT. bigger than stock | 04GTAMPA | Want to Buy | 7 | September 27th, 2007 01:20 PM |
| Bigger MAF, Bigger Injectors??? | oms4life | 5.0 Mustangs | 14 | August 28th, 2007 11:47 AM |
| Gonna need bigger injectors yet? | mustangman9550 | Street | 6 | March 2nd, 2007 08:20 PM |
| what will bigger injectors do? | adamo41188 | 99-04 | 15 | January 23rd, 2007 06:40 PM |
| fuel regulator vs bigger injectors | 1990CA50 | 5.0 Mustangs | 7 | January 7th, 2007 02:34 AM |
