clutch diameter
Old August 24th, 2007, 09:15 PM   #1
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
clutch diameter
Is the 2000 GT clutch diameter 10 inches? I got a clutch from rpmoutlet and it was an 11 inch and was too big (was their only option). And also what spline is it? I think its 11? But need to make sure not making same mistake...
Old August 24th, 2007, 09:15 PM   #2
energiesource's Avatar
energiesource is on a distinguished road
10.5 i believe
Old August 24th, 2007, 09:16 PM   #3
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
10 spline, and i think its either 10 or 10.5
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old August 24th, 2007, 10:02 PM   #4
2000 GT
did some searching and most website have the incorrect size.... But i found some 10.4 inches 10 spline. Hope rpmoutlet takes care of me and their mistake of the wrong clutch size!
Old August 24th, 2007, 10:03 PM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I doubt it.
RPM outlet sucks man.
Old August 25th, 2007, 03:14 AM   #6
superbeef1000's Avatar
Originally Posted by HMUSN
I doubt it.
i second that,, but ftw tossin a new fidenza alluminum flywheel while you change it , it is set up to use 11'' or 10.5'' disk if i remember corectly
Old August 25th, 2007, 09:22 AM   #7
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
I doubt it.
thats what I was thinkin. When it comes to returning shit they suck major ass.
ΜΟΛΩΝ ΛΑΒΕ
Old August 25th, 2007, 09:29 AM   #8
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
10.5 inch 10 spline, if you go ahead and switch to the 11 inch, be sure you know what flywheel to get. either a 6 or 8 bolt so you dont run into any other trouble.
Threads Similar to: clutch diameter
"95 GT H-pipe diameter? MWWarlord General Tech 3 October 7th, 2007 02:58 AM
A little help with staggered diameter wheels. catchtheroadrunner 2005 - 2010 0 September 9th, 2007 04:48 PM
Diameter whtpny 99-04 7 August 30th, 2007 04:52 PM
Exhaust Diameter militant54 96-98 6 November 3rd, 2006 08:27 PM
Crank Pulley diameter 97TunedMustang V6 Mustangs 2 February 7th, 2006 07:26 PM
