x pipe question - Forums at Modded Mustangs
post #1 of 11 Old September 20th, 2013, 12:01 AM Thread Starter
96Mustang5.0's Avatar
x pipe question
Just grabbed a gray 04 gt, just wondering, I want an o/r x pipe but id like a kit that comes with the o2's and everything, any ideas/options, post links or whatever. Thanks guys.
96Mustang5.0 is offline
post #2 of 11 Old September 20th, 2013, 12:10 AM
They don't come with o2s. What's the problem with using your factory ones?
iammclovin804 is offline
post #3 of 11 Old September 20th, 2013, 12:16 AM
bigjohnstud4200's Avatar
If you do get new o2, make sure that you get OEM
Tuned by Joe@TrickTuners
CMS Stage 1 Cams, 4.10 Gears, TrickFlow 70mm TB & Plenum, MAC Prochamber with Pypes M80's, MGW Shifter, Custom Paint, Cobra Cloth Top, Staggered Chrome 18" Saleen's and Sequential Tails.
bigjohnstud4200 is offline
post #4 of 11 Old September 20th, 2013, 12:51 AM
MM's V6 Hater
iTrader: 31 reviews
The x pipe will come with o2 bungs. Just swap your current ones over. I've learned the hard way, only use oem O2's. you also may get a cel after the o/r swap. Either have the rear o2's turned off or have them deleted via tuner.
2010 GT500
2013 GT
2012 Dodge Ram 3500
Cabikejumper is offline
post #5 of 11 Old September 20th, 2013, 02:45 AM
Or look up the spark plug non fouler trick! I swear by these, no need for mil eliminators or having the rear o2's turned off.
Sburns015 is offline
post #6 of 11 Old September 20th, 2013, 03:10 AM
Anandavenkatakrishnan
dsgpony's Avatar
You have an 04 gt. Only 2004 required extensions for the rear o2's. I would get o2 extensions.
'04 DSG GT- Sold
'14 Sterling Grey GT (Megalodon)- Roush Blower, Longtubes, Coilovers, Brembos, Niche Wheels, a lot of other things. 615RWHP
dsgpony is offline
post #7 of 11 Old September 20th, 2013, 06:16 AM Thread Starter
Just don't want to go through the hassle of trying to get the stock ones out of the stock mid pipe.
I definitely will, seems like you guys know your stuff haha
post #8 of 11 Old September 20th, 2013, 11:13 AM
Cqd24's Avatar
The only thing that I had to do was unclip the little plastic o2 harnesses from the transmission brace thing (you'll see it). Once unclipped they reached perfectly and I tie wrapped them away from the pipe. Also, You may need an extension for your left front o2, I had one that looked like an oversized nut type fitting, and it worked perfectly.
'03 GT, O/R X, LM1, SLP Longtubes, HP292s, 4.10s
'02 C5 Z51
Cqd24 is offline
post #9 of 11 Old September 20th, 2013, 03:56 PM
Re use stock 02 sensors, get a set of MIL iliminators and call it a day.
2003 DSG GT COUPE / 5 Speed/Bolt ons/Exhaust/Corbeau/FR500/Canton/MM coilovers/H&R SS/Mach 1 Delete/SSBC Big Bite Rotors/ MMR RS Delete/MM CC plates/UDP
Broke is offline
post #10 of 11 Old September 20th, 2013, 09:35 PM Thread Starter
Mil elimintators are being bought. Will be posting a lot more in the 99-04 section
post #11 of 11 Old September 20th, 2013, 11:32 PM
Moderator
SSG Pate's Avatar
iTrader: 9 reviews
just reuse your O2 sensors, because new pipes don't come with them.
Convertible Crew Founder
Proud Iraq and Afghanistan War veteran
700 RWHP Club Member #1
Vortech T Trim @18 PSI
604 RWHP 516 FT LB
11.50@121.77@ 523RWHP
Precision Turbo 7675 CEA @ 20 PSI
738 RWHP 691 FT LB
10.9 @ 131 MPH
SSG Pate is online now
Human Verification
