transmission grinding after replacing clutch - Forums at Modded Mustangs
post #1 of 4 Old September 20th, 2013, 12:16 AM Thread Starter
please help. i have a 99 cobra and i just finished a clutch replacement. i replaced the clutch, pressure plate, throw out bearing. i started it up and put it into gear with no problem and when i release the clutch pedal it grinds like hell. i need help asap.
StonerFresh3 is offline
post #2 of 4 Old September 20th, 2013, 01:32 AM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
Did you adjust the clutch cable?
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is offline
post #3 of 4 Old September 20th, 2013, 01:42 AM
He of Long Wind
Mike in Kentucky's Avatar
Any chance you installed the clutch disc backwards?
BUILD THREAD
'84 Hatch, Bracket Car, 11.11@121.21, but I'm working on it
'71 Mach One FB 351c, Slow
'73 Torino, 302, Slower
Mike in Kentucky is offline
post #4 of 4 Old September 21st, 2013, 12:27 AM Thread Starter
i did adjust the clutch cable. and i did put the disk in the right way. i pulled the transmission again and i found my pilot bearing had pretty much exploded. could that cause the problem? if not the only other thing i could think of is something is wrong with my trans itself.
eliminated:
clutch
finger plate
flywheel
throw out bearing
clutch cable
Human Verification
