Engine question, 302?
Old August 25th, 2007, 11:40 PM   #1
energiesource's Avatar
energiesource is on a distinguished road
this may seem stupid but im just unaware of the boss 302 blocks
would it mount to our cars, and anything else factory or would i need to get new everything?
Old August 25th, 2007, 11:42 PM   #2
Proud American
MustangMatt96GT's Avatar
new K member, and it will be hard to get the computer to work
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old August 25th, 2007, 11:43 PM   #3
well is the size of the block the same and its just bored out, or is it bigger, which means nothing will fit above the pistons?
Old August 25th, 2007, 11:47 PM   #4
mattstang's Avatar
mattstang will become famous soon enoughmattstang will become famous soon enough
Send a message via AIM to mattstang
you are aware these arent the modular motors right
you can make anything work you just gotta justify it in your mind and finaces on that note nothing as far as engine would be the same not sure about tranny but if your a stick car new bellhousing etc..... maybe not sure
and you would probably need to be an electrical engineer to get the wiring system to work
Old August 25th, 2007, 11:49 PM   #5
Proud American
Yeah man, those are pushrod motors, like the old 5.0s. the 5.0 mod motors are ethier bored out to 3.700 inches or stroked with a 3.75 inch stroke, if i am not mistaken
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old August 25th, 2007, 11:53 PM   #6
i never really understood the difference between modular and pushrod to be honest. aside from maybe a fan clutch lol
Old August 25th, 2007, 11:59 PM   #7
Proud American
well a push rod has a cam down the center of the motor and then push rods from that to the valves in the heads basically. Where our mod motors, have 2 cams 1 in each head. the timing of the cams is done by chains and sprokets on the cams. DOHC have 2 cams per head.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old August 26th, 2007, 12:01 AM   #8
ah i gotcha
Threads Similar to: Engine question, 302?
engine question energiesource 99-04 6 August 14th, 2007 01:29 PM
engine question hopper 5.0 Mustangs 2 June 21st, 2007 10:01 PM
engine question Drixops V6 Mustangs 10 February 8th, 2007 08:50 PM
First Engine Mod Question... DSEZ V6 Mustangs 19 January 24th, 2007 09:14 PM
Engine Question man_of_war2081 99-04 19 November 16th, 2006 06:56 AM
