Discussing Check Engine Light in the 99-04 Forum. I would run without them for a while and see. I know alot of ppl ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
I know alot of ppl with MIL's and still get the CEL. I got the CEL a few times, but after I cleared it once, it never came back. MIL's = Junk IMO |
#22 | |
When you say clear it did you unhook the battery, or you took it to a shop or with a tuner?
CAI, o/r x-pipe, Flowmaster mufflers, 75mm TB,Predator tune,and bbk shorty headers, and just ordered upper plenum. |
#23 |
well i work at a dealership so i just cleared my DTC's.
but undoing the battery will do just as well for ya |
#24 | |
#25 |
anytime bro
Just save your money on the MIL's until you drive it a few months then decide what you wanta do. And btw, the cheap ass ones you see on ebay, they work just as good as the expensive ones do. They just arent as fancy. Bascially your just using a resitor and a capacitor to change the voltage readings from the O2 sensor out puts to the PCM. That way the PCM is tricked into thinking that the O2 sensor is reading properly. |
#26 | |
#27 |
well if i can run with out MIL's and not get a CEL/MIL then why cant everyone ya know
#28 | |
#29 |
i got a code 2 times, cleared and never came back, wife drives the vert now, and still no code, so im not sure if driving habits have anything to do with it or not. Dont take this as advice, take it as my experience.
#30 | |
#31 |
Well I can say never, she just learned how to drive a 5 speed in this car. I cant even get her to get on it when I tell her to. Which makes no differance really because the O2 sensors dont change voltage when you get on the throttle.
#32 | |
#33 |
not long enough to make a differance though
#34 | |
O2 sensor feedback is used after the engine is warmed up, at Idle, and at part throttle (cruise) conditions. Thats why it important to have properly working O2s .Cuz if your getting on and off the throttle ,the 02s need to switch on and off quickly.
Fryrice has left the building. |
#35 |
The car has 44k on it and I've reset the battery numerous times. And it's definatly not the MIL's because they are on the rear o2's, not the fronts. My code is for the driver's side front o2 sensor. I'm going to switch out the front two o2's from side to side to see if the code changes to the passanger side. That would indicate a bad o2 sensor. If it's not the sensor and the side stays the same then it's somthing else. Is there anyone else that my know what the deal is because I have no clue. And I don't think it has anything to do w/ my gas cap either.....
...Modded 1996 Ford Mustang GT... SOLD!!
...Modded 2001 Ford Mustang SVT Cobra... SOLD!! Now... ...Modded 2003 Ford Mustang SVT Cobra, Anniversary Edition.. www.cardomain.com/id/po1snd_u |
#36 |
Okay now the P0153 code is gone. Now it's the code P0155 which says the circuit has failed for the front driver side o2 sensor. Now does that mean it's bad? It's also throwing a P1000 which says the diagnostic testing failed to complete or something like that. WTF is this now???
#37 | |
P1000 is not actually a trouble code. It just means that the Readiness code has not been set yet or in other words, the engine computer hasn't completed testing certain emission control components. If there is no other problems with the car emission system, the code P1000 will disappear after driving for some time (the drive circle must include idling, stop and go traffic, acceleration and steady cruising). But until you get rid of that P0155 it probably not gonna complete.
#38 |
P1000 is ok, dont worry about that.
Fryrice, are you a ford tech? You seem to know alot . |
#39 | |
I appreciate the compliment though. Not a tech ,but I read a lot and have asked a lot of questions in the past myself. I know enough to keep me outta trouble and to do my own work etc. Sometimes when I know the answer to something ,but dont know the best way to explain it,Ill look it up and try and piece it together so the person asking can understand it if they are new to the car game. Im a decent Sherlock with lots of seat time I guess you could say.
Threads Similar to: Check Engine Light
| check engine light | 02ATIstang | 99-04 | 24 | May 22nd, 2007 06:03 PM |
| Check Engine Light | brose1388 | 2005+ | 4 | April 28th, 2007 04:26 PM |
| 95 3.8L check engine light | nikbait | V6 Mustangs | 3 | February 24th, 2007 03:57 PM |
| Check engine light | ByPopularDemand | V6 Mustangs | 18 | January 9th, 2007 02:50 PM |
| Check Engine Light? | GreenFaleen | V6 Mustangs | 13 | November 20th, 2006 03:26 AM |
