romeo or windsor
Old August 30th, 2007, 09:31 PM   #1
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
romeo or windsor
How can you tell if you have the romeo or windsor block.... if im not mistaken. the romeo has a w for the 8th digit in the vin and the windsor has an x as the 8th. if im wrong please correct me
Old August 30th, 2007, 09:36 PM   #2
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
wat is the difference b/t the 2? isnt the romeo used in the cobra?
Old August 30th, 2007, 10:12 PM   #3
yeah. but i think it was put in some gts also. kinda randomly. like they moved factories or something like that and used some of the romeo blocks for gts. they handle more hp and the windsor block
Old August 30th, 2007, 10:58 PM   #4
wow! they put romeos in some gt's? so that means there r some gt's driving around out there with an iron block and they dont even kno it? thats means for some serious HP!!! haha
Old August 30th, 2007, 11:12 PM   #5
Proud American
MustangMatt96GT's Avatar
Romeo was used from 96-98 and then mid 01-04 in the GTs
and read this Clicky
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old August 30th, 2007, 11:18 PM   #6
ooooo ok... so who makes the termi blocks?
Old August 30th, 2007, 11:47 PM   #7
bossman2kgt's Avatar
bossman2kgt is on a distinguished road
Heres some good readin.
http://www.mustangandfords.com/techa...or_blocks.html
Old August 31st, 2007, 12:31 AM   #8
that article didnt really help me much on how to determine if i have a romeo or windsor. lol. but thanks for tryin. maybe i didnt understand it correctly and you can point somethin out for me
Old August 31st, 2007, 02:49 AM   #9
Blackblurr_00GT's Avatar
Y2K GT
13.3@103
Blackblurr_00GT is on a distinguished road
THe windsors blocks are stonger b/c most of them came with and 8 bolt crank where as the romeo block came with a 6 bolt crank
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature.
Old August 31st, 2007, 03:10 AM   #10
superbeef1000's Avatar
the romeo has 11 bolt valve covers
Old August 31st, 2007, 06:09 AM   #11
AnglicoGT98 is on a distinguished road
Send a message via AIM to AnglicoGT98
+1. the best way to tell is that the romeo heads have 11 bolts in the valve cover and the windsor have 13. That simple. To my knowledge there isn't a HP difference in the two. Also, windsor have a press on camgear and romeo has a bolt through it. And like Matt said, romeo was from 96-98 and mid 01-04. Windsor was 99-mid 01. Just count the bolts...
Old August 31st, 2007, 08:13 AM   #12
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
What???????????????
SOME of the Windsor blocks came with an 8 bolt CAST truck crank, because Windsor could not produce enough parts to keep up with demand and Romeo was not building anything during this time frame. If you believe the Windsor design to be superior to the Romeo, you have not been into these motors. There are only two major differences- 1. The main bearings have a different design and 2. the Romeo has cam girdles as opposed to the Windsors cam straps.
The amount of misinformation that gets spit out around here is retarded sometimes.
Old August 31st, 2007, 08:14 AM   #13
MM's Mad Scientist
acmillr's Avatar
Slow Fella
All GT's have an iron block.......
Old August 31st, 2007, 03:24 PM   #14
DrHolliday is on a distinguished road
I was gunna say the same thing.
As for the best way to tell, romeo has 11 valve cover bolts, windsor has more. I beleive its 13 but I could be wrong. Its been a while since I ready it.
I also know that my GT had the romeo block and the vin had X in it.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old August 31st, 2007, 04:11 PM   #15
So does somebody know for sure what the x stands for in the vin number? Not doubting you Holliday just making sure.
Old August 31st, 2007, 09:22 PM   #16
sstang is on a distinguished road
I believe the X stands for the 2V motor, I could be wrong?
Old September 1st, 2007, 09:48 AM   #17
1967 mustang coupe
ma67cpe is on a distinguished road
Send a message via Yahoo to ma67cpe
try this
https://www.fleet.ford.com/maintenan...ls/default.asp
Old September 1st, 2007, 12:23 PM   #18
Badasstang281's Avatar
Badasstang281 is on a distinguished road
Send a message via MSN to Badasstang281
Will put in me vin and it said 225 HP is that right
Engine Type - 8th Position
VIN Code: X
Engine: 4.6 L
Cylinders: 8
Fuel: Gasoline
Horsepower: 225 HORSEPOWER
BBK cai P&P 75mmtb P&P plenum BASSANI exhaust MAC x-pipe NO CAT"S ACCEL direct fire coils NGK iridium spark plugs lX7 Eibach pro-kit springs
Old September 1st, 2007, 12:39 PM   #19
After punchin in my vin it also just says vin code:X. So still not sure.
Old September 1st, 2007, 04:08 PM   #20
MM's Mad Scientist
acmillr's Avatar
Slow Fella
X supposedly means Windsor while the W means Romeo- I always thought that was a little backwards.
Threads Similar to: romeo or windsor
which one to have Romeo or Windsor shamntgmry 99-04 75 October 18th, 2007 09:33 AM
romeo or windsor energiesource 99-04 1 September 29th, 2007 01:59 PM
romeo vs windsor? mystang0673 99-04 0 March 5th, 2007 11:52 AM
romeo or windsor TrueBlueGT01 99-04 5 December 10th, 2006 01:26 PM
11 bolts = romeo or windsor niubodybuilder05 99-04 4 December 6th, 2006 07:19 PM
