MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
D1SC
OK, most of you know that I am not a very educated person when it comes to superchargers. So, I have a question that I am sure will get mixxed results.
With a fully built motor with power much like I have put out in the past (around 310HP), some strong SC specific cams, and a Procharger D1SC, how much HP would I be capable of producing- hypothetically speaking? Also, how much boost is the D1SC capable of efficiently maintaining? The Procharger website lists the maximum PSI of this unit at 32 lbs., but I am almost positive that this rating is slightly higher than the real world number.
I believe it is capable of supporting up to 800-900 hp
2000 GT Procharger Stage 2, D1 head unit, 10 lbs of boost/ 3 core intercooler BBK shorty headers BBK intake and T/B Flowmaster Exhaust 3:73 gears MGW shifter Full suspension, uca, lca, subframes, shocks, springs, caster/camber...etc. |
Proud American
it starts dropping off in performance at around 18 PSI and you wil need a cog to do that amout of PSI effecinently!
1990 GT
you could definitely make 18psi easily with it. i am making 13 psi with a pseries blower with vt heads and blower cams. i think with my set up if i upgraded to the d series it would make over 600rwhp. the d series is a good blower.
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
MM's nicest mod, :)
i see the most you make with that is the middle to upper 600rwhp range. And that with race heads and some healthy cams and intake. It is a pretty good blower but not that effiecient at upper boost levels. Just get crazy and get the new and improved F1C, capable of efficiently pushing 30lbs
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
there are guys taking the d1sc past the 800rwhp mark efficiently. just like you stated, that motor will just have to be built specific for the high boost. much more than that, the f-1 will be the better choice.
MM's Mad Scientist
Slow Fella
Thanks for all the input guys. I think the D1 will work for what I am wanting.
Threads Similar to: D1SC
| Procharger P1SC vs. D1SC | marcfiebka | 99-04 | 11 | December 30th, 2008 09:17 PM |
| so why is it overheating ??? Mustang GT - Procharger D1SC | SUPERCHARGED_GT-2005 | 2005 - 2010 | 2 | March 14th, 2007 07:27 PM |
| Procharger D1SC | 94GTD1SC | 94-95 | 5 | February 20th, 2007 09:46 PM |
| D1SC Installed | formgen | General Tech | 3 | February 12th, 2007 04:00 PM |
| What pulley size for 12 p.s.i. with D1SC? | formgen | General Tech | 1 | January 19th, 2007 01:55 AM |
