am i losing hp???
i own a bullitt with 91 on the clock these r the mods
k@n drop in 160 thermo long tube headers slp catback, with straight pipes no cats x pipe recenater mufflers (2 1/2 tubing) lower control arms panhard bar 4.10's predetor with custom tuning deep dish bullitts short shifter 100 shot zex wet i replaced the iac, cleaned the filter and maf. sprayed some stuff like sea foam in the system to clean everything reguler motorcraft recomended oil and im pushing 263 naw where a lil while ago i was pushing 270(n/a) i lost 4 hp and still with all of this. shouldnt i get more power? my numbers on spray r 330rwhp is this right or is something wrong? i know the dyno reads the car off cuz of the gears. how does that work, and i did this in 315 sumitomos if that helps.
48.47@ 12.58
welcome to the forums.
sounds like you need a dyno tune instead of a canned tune.
your numbers will vary based on weather conditions. i wouldn't think too much of just a few horsepower difference.
hey thanx all. lol first post. i live in vegas. i guess your right but wit the mods is this good numbers
what about the gear thing whats the math on that
#6 | |
he said custom tune in his list of mods |
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
i would say thats about right with the mods listed
the numbers sound pretty good but i think you should be getting more out of your nitrous. you're only getting 60hp out of the 100 shot, you should be getting close to a 100 with a good tune.
48.47@ 12.58
a custom tune is a fancy word for canned tune
depends on who you ask
he's obviously had it on a dyno so why is it hard to believe that they didn't tune while it was on there
yea well i also forgot to mention the botle opener and purge kit.. it was done by the guys at the speedway. i seen a bullitt there all the time and figured they reg my car. i remember that they said that i should only tap the purge like 2 times to let the air out. i went to the track and they said to do it till u c white smoke. this makes more sence 2 me is that true
48.47@ 12.58
i just think with a dyno tune you should be able too pull out a bit more than that is all
the guys prob gave me a safe tune thats all
2000 Mustang Gt
13.56 @ 106
seems a little low to me
id do an n/a dyno to see where you at there. should be around 260 rwhp i would think elevation and weather make a big difference too wut is your elevation?
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams Manley Valves/Springs - Centerforce Dual Friction BBK LT's - BBK o/r H - Bassani catback FRPP 4.10s - XCAL2 - BBK UDP's 306rwhp/333rwtq |
elevation. heck if i know. i been trying to find out and no one knows. this club from az came for the race track and they were pulling 13 and 14's and there cobras as we all know pull 12's. they said we have bad elevation air density is good i would think
2003 SVT Cobra
11.70 @ 121
what kind of dyno were you on each time?
MM's nicest mod, :)
dyno's can read different every time you go, at the same dyno i made 296rwhp and went back the following month and made 283rwhp, You are not losing hp, just going to different every time depending on weather, how hot the car is, the load they put on the car. The real difference is in the way it drives and how fast you go at the track.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
Proud American
Dynos suck!!
Quarter Mile Times are where its at!
Bearer of Bad News
I has mustang and legacy.
Slower than my Ruger.
Vegas = Extremely high temps = not so happy engine
I was stationed out there and the hotter it got, the more power I lost. Same thing out here, plus I have 4,000% humidity. Effing Alabama. Anyway, heat will make your car very not happy. Definitely robs some of it's power. I used to love driving up around Red Rock/Blue Diamond. The desert is gorgeous out there.
~MOD NUTSWINGER~ My Tongue Soothes Razorburn ![]() STOPSAYINGFAIL.COM EVERY FART IS A GAMBLE Just Think Of Me As A White Blood Cell.
Threads Similar to: am i losing hp???
| Losing streak | ByPopularDemand | V6 Mustangs | 15 | August 7th, 2007 08:28 PM |
| losing oil pressure | marks87gt | 5.0 Mustangs | 7 | July 14th, 2007 07:27 PM |
| Losing HP | B.A.M302 | 5.0 Mustangs | 25 | March 24th, 2007 10:38 PM |
| Losing Battery Power Somewhere *SOLVED* | Notcho | 5.0 Mustangs | 20 | November 14th, 2006 02:59 AM |
| losing power | blak88stang_gt | General Tech | 1 | April 2nd, 2006 09:40 AM |
