LinkBack (1) | Thread Tools |
#1
13.6@102
White SMoke, ran compression test...
I have a procharger on my engine low miles. ANyways just got it tuned on tuesday took it out to the track and ran like a bat outta hell for the first two runs than on my last run of the night i put it into fourth gear and it felt as though i slapped it into second. The car shook really hard than shut down. I got it towed home and tried to start it again and my buddy said it had white smoke coming out of the pipes. Shit i thought head gaskets? I ran a compressions test all 8 spark plugs were reading from 155 - 163 psi. So that made me wonder, could my sct chip have just failed or something? when i start the car it idles really bad, eventually shutting off. Anybody had this problem or can help me out with solutions? I checked the oil and it has a gassy smell to it. My spark plugs are really black, but the car was running rich though with my tune. When i run the car for its short time period my wideband reads off the charts rich before it shuts down. IT kinda runs like it did when i first started my car with its 42 lb injectors and procharger fora few seconds without the chip.
Boost gets you laid
check and make sure all of your clamps and hoses for the charger are on properly, and there are no air leaks.. sounds like it could be a MAF sensor problem maybe?? it could be thinking that there is way more air getting in and therefore be dumping too much gas into the engine..
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
13.6@102
YEs my tuner called from AFI performance in Edmonton and said the exact same thing, he said check my MAF, he said its defintly a tube just falling off, i checked it and he was right, car runs like a champ all that wasted time checking compression geez. Anyone looking for perfomance in Edmonton area should give AFI a call and ask for Martin, he called me before i called him just b/c he heard something happened with my car and got my problem fixed in no time.
Procharged 383 rwhp/ 391 rwtq |
13.6@102
Thanks to you too also bob i would have been right back on here if he didnt call.
Now that's fixed I'd run some sea foam through it to clean off the spark plugs.
Boost gets you laid
damn i'm good!!!
i'm glad you got it fixed bro. i should become a mustang builder/tuner. that'd be sick.
Boost gets you laid
oh yeah and +1 on what NBK said..
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
seafoam is da sheeeznitt
13.6@102
what the heck si seafoam?
#10 | ||
![]() you're welcome.
#11 | ||
http://www.seafoamsales.com/motorTuneUpTechGas.htm
#12 | ||
2006 Mustang GT
2002 GT
Good to hear you go it back running. You can definatly use the sea foam to clean the plugs. Personally i would just change them out, just to make sure they are good.
02 GT... JLT Cold Air/ Diablo Tune/ MAC Catback Exhaust/ FRPP 3.73's/ Steeda Triax/ Eibach Pro Kit... A work in progress. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/33528-white-smoke-ran-compression-test.html
| Tom Van Vleck Website Access Statistics | This thread | Refback | January 17th, 2009 10:34 AM | |
Threads Similar to: White SMoke, ran compression test...
| That white smoke | ByPopularDemand | V6 Mustangs | 19 | April 19th, 2007 11:56 AM |
| white smoke at idle | product1620 | 96-98 | 10 | April 11th, 2007 05:37 PM |
| My white smoke problem | ByPopularDemand | V6 Mustangs | 17 | March 22nd, 2007 11:44 AM |
| white smoke | zero | 5.0 Mustangs | 47 | March 20th, 2007 12:22 AM |
| white smoke? | ByPopularDemand | V6 Mustangs | 31 | March 6th, 2007 03:15 PM |
