Discussing Oil Filters in the 99-04 Forum. I use K&N or Motorcraft oil filters.... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#41 |
2006 Mustang GT
#42 |
2001 mustang gt
valvoline oil and wix filter
#43 |
+ 1 for mobil 1 :award
#44 |
Motorcraft
Black 03 GT SLP LM1 exhaust Hellion 62mm Turbo Kit 405 RWHP--458 RWTQ Stock LOOKING.... http://i8.photobucket.com/albums/a31...odhatesyou.jpg |
#45 |
Motorcraft filters do just fine
![]() 2001 GT Stang "Bullitt #5583 wanna-be" Best ET 13.8 104mph (b4 motor/gear) D.S.S. ProMod ShrotBlock, DiabloSport Predator, Steeda TriAX, FRPP 4.10s & D-shaft, FRPP 24# injct, Flowmasters, 03 Cobra Brakes, one awesome tune & much more ;] |
#46 |
mobil 1 for me.......they actually get small particals than fram....fram are good filters too.and they are cheaper.. but i believe in the mobil 1's
#47 |
01 Cobra
Purolator Pure One Filter 5.66$
5 Qts Royal Purple 40.08 $ = 55.62$ 1 Qt Lucas Oil stabilizer 9.88$
#48 |
I only use k&n for my oil filters.
K&N Performance Gold (Part #HP2010) - $13.48 FRAM (Part #DG2) - Double Guard - $21.99 FRAM (Part #XG2)- X2 Extended Guard - $16.99 FRAM (Part #HM2) - High Mileage w/TRT - $7.99 FRAM (Part #TG2)- Tough Guard $6.18 FRAM (Part #PH2)- Extra Gurad $3.77 Mobile One Filter (Part #M1210) - $9.88 Purolator (Part #L24651) - $3.24 Purolator Pure One (Part #PL24651) - $5.88 Motorcraft Filter (Part #FL820S) - $3.88 Bosch Premium Filter (Part #3410_ - $5.99 ACDelco Filter (Part #PF1250) - $3.97 There are a few others out there, STP, Pentuis, and Pennzoil that all fall under the four dollar range. For just the daily driver any of these will be an ok application. It just comes down to personal choice. I just like the k&n filters because of the 1" nut welded to the top for easy installation and removal. They also claim to use a thicker canister wall then others and a higher flow rate and to be honest my cars seem to run better, probably just in my head! ![]() FRAM drives me crazy with all the different flavors they have but they still make a decent filter. They just seem to make it too hard. Sorry for the long post and I went ahead and added the part numbers if anyone needs them. Also these prices came directly off of Advance Auto's website. AutoZone seem to be just a tad cheaper.
#49 |
Make sure whatever oil filter you use that it is equipped with the relief valve. This prevents oil drain back from the filter when your car sits. The relif valve gives you instant oil pressure at start up. Some of you cheap filters do not have this. I use Motorcraft and Mobil 1 every 3500 miles.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
#50 |
i heard mobil 1 istn 100% fully synthetic anymore? this true?
2008 roush 427 2003 mach1- 4 10s, mac prochamber, JLT short ram. soon- 03-04 cobra bumper, 10k hids, and d1 sc procharger |
#51 |
motocraft filter with mobil1 5w20
#52 |
I use German Castrol for oil and auto zone had a deal if you buy 5 qts. of castrol you get a bosch oil filter for free so thats what I went with...other than that I usually use motorcraft.
#53 |
2000 mustang gt
motorcraft or puralator
![]() i hate horses |
#54 |
a filter is a filter the main thing is changing it offen
![]() 2000 ford mustang gt convertible 2004 ford lightning truck 2001 ford mustang/cobra 2008 ford f-350 4x4 truck |
#55 |
2001 Mustang COBRA
13.39@106.36
all oil filters do the same thing
#56 |
That is absolutely a false statement. Not all oil filters have pressure relief valves for one. Two, there are different filter medias out there depending on the type of useage your engine is going to have. Cut a standard frame filter in half and then cut a Ford Racing filter in half. Then note the differences.
#57 |
2003 Ford Mach
Traveling at the speed of a photon
if im correct filters like k&N and mobil 1 tend to capture smaller particles than your standard filter or they tend to let more oil flow freely without capturing many of the miniature particle
its either one of those but they all work great. ANYwho mobile 1 supersyn with lucas oil stabilizer and a mobil 1 filter and off you go! oh and my opinion on royal purple is that its a waste of money on a DD
![]() Under my Umbrella! Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. |
Threads Similar to: Oil Filters
| air filters and batteries help | 92stang0802 | 2.3 Mustangs | 9 | July 13th, 2007 10:19 AM |
| CAI filters | Murderjetz | General Tech | 4 | July 3rd, 2007 12:41 PM |
| bbk filters aren't preoiled right | YNOT | General Tech | 2 | June 24th, 2007 06:13 PM |
| Oil Filters | ridebmxfbm | 5.0 Mustangs | 9 | March 30th, 2007 02:18 PM |
| Fram Air Filters | Mustangfan99 | V6 Mustangs | 8 | September 26th, 2006 03:13 PM |
