Discussing Electrical problem? in the 99-04 Forum. Yeah, so yesterday when I was leaving my class I start up my car and ...
Old September 7th, 2007, 07:26 PM   #1
Garhfer's Avatar
2004 Mustang GT Conv.
Electrical problem?
Yeah, so yesterday when I was leaving my class I start up my car and all my windows would go down except my driver side and then my car almost stalled then the lights during almost stalling and then my driver side window worked... almost it's been stalling like randomly like once every week or so lately... any ideas? everything is up to date on maintenance...
2004 GT Boosted by Vortech
Old September 7th, 2007, 07:44 PM   #2
check the alternator ?
Old September 7th, 2007, 07:48 PM   #3
Garhfer's Avatar
I thought the same thing but I thought it would drain the battery if the alt was bad not stall the car right?
Old September 8th, 2007, 12:14 AM   #4
Garhfer's Avatar
bump, don't anybody know?
Old September 8th, 2007, 12:21 AM   #5
Def not the alternator, that would drain your battery
Old September 8th, 2007, 12:23 AM   #6
I would say you have two seperate problems. Your window switch should have nothing to do with the car stalling.
Old September 8th, 2007, 12:33 AM   #7
neckbonekat's Avatar
That's an interesting one. I think I have a short somewhere because when I put a fuse in the slot for the AC/rear defrost it blows immediately.
2001 BULLITT GT
I DON'T CARE WHERE THE CAR IS MADE. IF YOU CAN'T BEAT IT DON'T TALK SH*T!
Old September 8th, 2007, 12:35 AM   #8
yeah if it blows immediately it's a direct short
Old September 8th, 2007, 12:36 AM   #9
what are you doing when it stalls? engine at idle? coming to a stop? tranny in gear or out?
Old September 8th, 2007, 12:39 AM   #10
Garhfer's Avatar
well, I just got out of class when it happened, I started up the car and then tried to put down the windows and the driver's side window wouldn't work but all the others would, and then the lights dimmed and it almost stalled... and it wasn't in gear or anything... after it almost stalled the driver's side window worked... was weird...
Old September 8th, 2007, 12:45 AM   #11
the way you just described that sounds like the power window motor was draining all of your electrical power. its possible that could have caused your engine to almost stall
Old September 8th, 2007, 12:49 AM   #12
Garhfer's Avatar
Does that mean it's becoming faulty? It's the first time it's ever done it, but it'll dim all the lights in my car when I use it since I've had it...
Old September 8th, 2007, 12:53 AM   #13
they usually will dim the lights some, but they shouldn't cause your engine to almost stall. i wouldn't think your window motor is already going bad but it is possible. do you use them a lot? do you have udp's?
Old September 8th, 2007, 12:54 AM   #14
Garhfer's Avatar
No but I have a supercharger... and yeah I use them a lot... unless it's really hot.
Old September 8th, 2007, 12:58 AM   #15
did it make any odd noises when the windows wouldn't go down? humming or anything?
Old September 8th, 2007, 01:00 AM   #16
Garhfer's Avatar
The supercharger? I don't think so... it's always got it's loud noises it makes lol...
Old September 8th, 2007, 01:00 AM   #17
no the power window motor
Old September 8th, 2007, 01:05 AM   #18
Garhfer's Avatar
Oh, no it didn't make any noise like it wasn't working at all
Old September 8th, 2007, 01:12 AM   #19
the window could have been binding. but thats not common with a vehicle that is so new. you could take off your door panel and inspect everything, make sure everything is still attached securely.
Old September 8th, 2007, 01:24 AM   #20
Garhfer's Avatar
It all works fine it just did it that one time doesn't even make a sound when used since then either... I dunno it's just weird...
Threads Similar to: Electrical problem?
Electrical problem..... Klawin Electronics 0 September 18th, 2007 10:24 PM
Big Electrical Problem scr110 Electronics 8 June 16th, 2007 11:26 AM
electrical problem Darren E 5.0 Mustangs 4 April 18th, 2007 05:00 PM
Electrical Problem terribleonexx88 5.0 Mustangs 12 November 6th, 2006 03:37 PM
Electrical Problem 90Stang 5.0 Mustangs 12 November 2nd, 2006 03:00 AM
