transmision ?
how do u change the transmison fluids or the gears fluids need help first ford i have had ty
manual or automatic transmission?
Gear oil you just take off the differential cover let it drain out put it back on with permatext and then fill it back up from the fill plug on top, manual transmission just take out the drain plug of the transmission pan drain, put it back in and put the fluid in the fill plug or can take out the shifter inside the car and dump it in from there which is easier...
![]() 2004 GT Boosted by Vortech |
how many bottles fill one manual trans and wats the best oil to use for that and is mixing bad
^ what he said
use synthetic atf fluid, if you have the 3650 transmission only put in like 3.4 quarts dunno about other transmissions...
cuz idk wat oil was put in there before and wat brand would be that kind of oil and would it be easier to do wen i put my short shifter
and if so is mixing the oils bad |
use royal purple, for everything, it's really good oil!
#8 | |
wats the best oil weight for a 04 mustang gt rite now im using penzoil 10w 30
#10 | |
#11 | |
wen i do my next oil change would it mess anything up if i change to 5w 20 from 10 w 30 or is it fine has long has i drain it and should i pour some seafoam before i change the oil to loseen evrything up need help
#13 | |
by using the seafoam how would u suggets i do it plz dont wanna fuck anything up should i pour seafoam and let car run alittle then shut off teh car and begin to drain
and how muchn of the bottle should i pour in
what kind of climate do you live in? here in tx in the summer i usually use a little thicker oil because of the heat
i live in south florida
I use 5w 20 in Florida, haven't had any problems... I always let my car warm up too.
but wen pouring the seafoam down the oil cap tube do i pour in the whole bottole of how much of the bottle of seafoam and then should i run the car or right after i pour it in begin to drain
and for my v8 gt how many bottles of royal purple would i need
Threads Similar to: transmision ?
| transmision ? | usspfnorman | V6 Mustangs | 6 | October 30th, 2007 10:55 PM |
| transmision noises | El_Cangri | V6 Mustangs | 22 | April 6th, 2007 02:14 PM |
| transmision removal | stangergt1 | 5.0 Mustangs | 2 | April 5th, 2007 12:30 PM |
| How Do You Add Transmision Fluid To A 02 Mustang | ChargerAg | 99-04 | 10 | October 30th, 2006 01:01 PM |
| Transmision | parkershard | 5.0 Mustangs | 3 | October 4th, 2006 10:24 PM |
