Questions About Engine Swapping and Kenne Bell
Old September 8th, 2007, 05:36 AM   #1
OcOnnor220 can only hope to improve
Sean Hyland Motorsports has a Kenne Bell twin screw supercharger kit for the 99-04 GT, I was just wondering why they offered the kit in both intercooled and non-intercooled versions...Without the intercooler Id need an external source of cooling for the kit? Also, I'd really like to supercharge my engine without blowing it...Is it recommended I get this thing bored out or add stronger accessories like better valve covers or bigger fuel injectors? Is it true you have to use premium fuel once you do this (thats gonna suck, I just got a promotion though)...
Part two is about the engine itself...If I was able to get a substantial (and safe) increase of horsepower without ruining the car (I drive it everyday, its my only car) then Id keep the motor in and only have to worry about maintaining the small stuff cause I would'nt be upgrading it any further...When I install an overhead blower do I have to cover the exposed engine cyllinders when I remove the intake and/or valve covers? I know thw gaskets are delicate...how do I torque correctly making sure I dont damage anything? I dont have to drain the engine do I?
Finally, is my 8.8 rearend strong enough to handle a 50-85 added HP output? The way I see it I can easily get all this done in my own driveway for under $6,000 Any help is appreciated thanks.
Old September 8th, 2007, 06:46 AM   #2
Assistant to the Manager
Smoothgrandmama's Avatar
12 GT
8.46@88 1/8
Smoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really nice
iTrader: 6 reviews
Send a message via AIM to Smoothgrandmama Send a message via Yahoo to Smoothgrandmama
Your gonna get alot more than 50-85hp More like 150-200HP.
The stock internals can handle about 450 RWHP But a good safe tune is very important.
And Yes You would have to use premium fuel
An intercooled kit will produce the same amount of HP with less Boost.
The kit Should come with aftermarket injectors and I don't think valve covers matter.
And If plan on racing it with sticky's then yes. But I don't think You could find enough traction on streets to break it unless Your launching at high rpm's all the time....or once!
Join The MM Facebook:
Modded Mustangs Facebook
Vote For Modded Mustangs Ride of the Month
Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng
Old September 8th, 2007, 11:43 AM   #3
Smart to switch to synthetic oil? Does the system (for both the fuel and oil if necessary) have to be flushed upon installation or just drained? I mean if I bolt this beast on and drive mildly to use up the rest of the regular fuel will it harm the blower? One more thing...whats a good air intake to compliment this thing? Thanks. Greg
Old September 8th, 2007, 01:08 PM   #4
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
I'd just dump some octane booster in it for the left over regular gas, switching to synthetic oil is always a good choice, and just drained for the oil.
2004 GT Boosted by Vortech
Old September 8th, 2007, 01:12 PM   #5
blue03mach1 can only hope to improve
jlt is one of the best intakes out there
Old September 8th, 2007, 01:31 PM   #6
2002 Chevrolet Impala
TheBusher will become famous soon enoughTheBusher will become famous soon enough
The non-intercooled KB is a 6 PSI kit, which KB says is good for about 350 rwhp (over 400 flywheel HP), which is about 125 rwhp gain (assuming you're stock). The intercooled KB is a 9 PSI kit, which KB says is good for about 430 rwhp which damn neer doubled your output for a solid 200 rwhp gain (over 500 flywheel HP). This kit is intercooled because as boost goes up, so does temp. You won't need an external cooling source if you get the 6 PSI kit, and the 9 PSI kit comes with one, so just use whatever comes with what you order. It all depends on how much power you want. As far as the engine being able to handle that much power, the rods are rated at 450 rwhp (about 530 flywheel HP). Those power ratings are also for a manual, if you have an auto, KB says you can expact about another 6% (I think) lose in power at the wheels, but your flywheel HP will remain the same..
Old September 8th, 2007, 02:24 PM   #7
Sounds great thanks guys I think instead of replacing the whole motor this is what Im gonna do...I actually for a while thought Kenne Bell only made a blower for the 03/04 Cobra but since I found this thing it looks like a better way to spend $5,000.
Old September 8th, 2007, 03:42 PM   #8
No prob, if you need anymore info check these out:
http://kennebell.net/techinfo/techinfo-ford.htm
or
http://kennebell.net/superchargers/f...2v/gt96-04.htm
and if you really get power hungry
http://kennebell.net/superchargers/f...t99-04_26L.htm
Threads Similar to: Questions About Engine Swapping and Kenne Bell
Kenne Bell Emay General Tech 16 October 16th, 2007 11:52 AM
kenne bell ZoomZoomMFer 96-98 6 August 27th, 2007 11:16 AM
kenne bell punkafi888 General Tech 43 April 4th, 2007 03:52 PM
Kenne Bell Going In! VegasGT 2005 - 2010 15 October 9th, 2006 06:00 AM
Kenne Bell 03blownmach1 99-04 11 June 28th, 2006 01:04 AM
