Need help fast!
Old September 9th, 2007, 11:14 AM   #1
04Pony's Avatar
04Pony is on a distinguished road
Need help fast!
This morning, while leaving my favorite coffee shop, I had to get in it a little bit to get on the main road between some traffic. I think I got in it a little too much because at around 4800 RPM the motor started making a very loud clicking noise, from inside the engine. It increased with RPM and was very loud, I immediately pulled over to check and see if maybe something had gotten stuck in the serpentine belt or if my cai had come loose from the fender mount, no problems detected. I got back in a started it back up, still clicking very loudly (top end noise, coming from pass. side cam cover) and decided to nurse it to the closest parking lot, all of a sudden the noise just disappears, the car is running great again! Anyone have this happen to them before? If so, any idea what it might be? And should I be worried about it? 2004 Mustang GT, bone stock engine, 58,749 miles, 5 speed, has traction control too.
2004 Mustang GT, 5SPD, Black/Black, Steeda Tri-Ax, Steeda CAI, 3.73 Motive gears
Old September 9th, 2007, 11:42 AM   #2
MasterDeBater
Smoothgrandmama's Avatar
12 GT
8.46@88 1/8
Smoothgrandmama is a jewel in the roughSmoothgrandmama is a jewel in the roughSmoothgrandmama is a jewel in the roughSmoothgrandmama is a jewel in the rough
iTrader: 6 reviews
Send a message via AIM to Smoothgrandmama Send a message via Yahoo to Smoothgrandmama
Could be a broken peice off of a rod or something. and the clicking stopped 'cause it's sitting in the bottom of Your oil pan now.
Join The MM Facebook:
Modded Mustangs Facebook
Vote For Modded Mustangs Ride of the Month
Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal
Old September 9th, 2007, 11:51 AM   #3
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
ummm yeah man... u threw a rod. thats def what it sounds like, and if thats what it is ur motor is most likely done. but if its just a little piece of the rod and its not thrown (when it rams itself into the actual block) then ur gonna need a new one... but get it checked out man, it could be very very serious.
Old September 9th, 2007, 12:01 PM   #4
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
I doubt it's a rod or piece of one... He said the engine is running great again. I'm not sure on this, but maybe you weren't getting any oil on that side of the head. Maybe the passages were blocked for some reason and whatever it was eventually worked itself out of the way...
Are you sure the noise came from the engine? Were there any codes thrown when it happened?
I think you should drain your oil pan and see if there's any large "clumps" in there that could have stopped oil flow for any amount of time.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old September 9th, 2007, 12:20 PM   #5
04Pony's Avatar
No, it's definitely not a rod, the engine started running rough when it was clicking, once the clicking stopped it ran great again, wondering if it might be the lousy factory Ford valve springs? Never had a problem like this before on a OHC engine. Just wondering if anyone had this happen to them before. By the way, I change the oil every 2500 miles religiously, last oil change was done 2 weekends ago, and I replace the filter everytime also. Car has been babied, every now and again I get on it a little bit, but never break the tires loose or over-rev it.
Old September 9th, 2007, 12:42 PM   #6
bossman2kgt's Avatar
bossman2kgt is on a distinguished road
Whats your oil pressure....check your dipstick.
Old September 9th, 2007, 01:03 PM   #7
04Pony's Avatar
oil pressure is normal according to the guage, not overheating, plenty of oil too. Running like new now, have no idea what could have happened.
Old September 9th, 2007, 01:05 PM   #8
HMUSN's Avatar
iTrader: 9 reviews
i would still pull the valve cover and take a look.
Old September 9th, 2007, 01:13 PM   #9
energiesource's Avatar
energiesource is on a distinguished road
now i know this isnt the same thing, but my friend has a chevy silverado, POS but whatever, his truck make a ticking noise, gets louder as it warms up usually, he took it in and some guy was like oh you just have carbon in your injectors, which i think is a load of bs because i doubt it would do that but would that be a rod?
Old September 9th, 2007, 01:51 PM   #10
1999 Mustang GT
13.21@104.5
DCstangGT is on a distinguished road
very possible because thats what it was like when my bearing went bad
Old September 9th, 2007, 02:22 PM   #11
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
Did you see any smoke or smell anything weird?
Def not a bottom end issue. No codes either huh? I was thinking blown plug for a minute cause it was running rough...
Then I thought bad lifter for a minute, then it oiled up again and now it's fine...
Definitely check it out closely by listening to it from up close. If you can pinpoint the smallest tick, let us know...
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Old September 9th, 2007, 03:37 PM   #12
superbeef1000's Avatar
pull the valve cover and inspect the followers and lifters maybe one jumped ship on you these cars are known for this problem
Old September 9th, 2007, 06:16 PM   #13
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Is this a pushrod engine? I have a Chevy truck that has a weak hydraulic lifter. In cold weather it will tick until the engine warms up.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old September 9th, 2007, 07:22 PM   #14
nope no push rods but they do have lifters and folowers in the heads
Threads Similar to: Need help fast!
Need help fast! dunechic Circle 7 December 5th, 2007 12:44 PM
Need Help FAST ocsailor86 96-98 2 June 18th, 2007 05:59 PM
how fast stang638 V6 Mustangs 21 April 5th, 2007 01:04 AM
Fast Fox!!! Stangzilla Videos 3 March 5th, 2007 12:32 PM
