Rotating assy - Page 2
Old September 9th, 2007, 07:57 PM   #21
camarosRgay is on a distinguished road
haha my fingers r too big for this f*ckin key board
Old September 9th, 2007, 08:01 PM   #22
Drgnracin72's Avatar
the big bore setups are the way to gow tih a modular motor, better power capabilties. it requires an aluminum block and MIT wet sleeves to get the bore out that big. its expensive but mkaes better power and will last longer than the strokers. and they will hold up to the same kind o boost the others will hold. but theyll make more power, becasue they have the potential to flow a lot more air
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old September 9th, 2007, 08:04 PM   #23
so a bored cobra motor will do it - im thinking of gettin a 95-98 cobra motor, also would the old lincoln mark engines do the same job - i noticed that they are transverly mounted - would i be better off with a 96-01 cobra motor (less hassle)?
Old September 9th, 2007, 08:07 PM   #24
the cobra motor ould be better, and yes you can do the wet sleeves on the cobra motor, but if your using 4v heads, there is no point at all
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old September 9th, 2007, 08:39 PM   #25
Proud American
MustangMatt96GT's Avatar
yeah i would say just buy an alumium block that is already wet sleeved to 3.700 or get an aluminum teskid block out of a 96-98 cobra and get it wet sleeved to 3.700 and use PI hand ported heads with custom cams! Right there with it still being streetable, 375 will be easily acchieveable. By boring it out, the heads are able to flow more air!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old September 9th, 2007, 08:54 PM   #26
what do u mean no point with 4v heads?
Old September 9th, 2007, 08:56 PM   #27
Proud American
4V heads flow well already, you dont need to bore it out to get 375+ RWHP
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 9th, 2007, 08:58 PM   #28
well yea but my goal is a hellva lot higher than that
Old September 9th, 2007, 08:59 PM   #29
Proud American
well with a blower you can, but with out nitrous or a blower or tubo its nearly imposible on a stock displacement 2V
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 9th, 2007, 09:00 PM   #30
02StangGToWNEr's Avatar
2006 Mustang GT
02StangGToWNEr is on a distinguished road
+1
It takes less work to get more power from the 4V's.
Old September 9th, 2007, 09:22 PM   #31
like i said in the pm, if your sticking with the 4v dont even bother stroking or boring. if going wiht the 2v stroke it unless you can afford tohave the block done. its not cheap at all. your looking at over 3 grand just for for the sleeving, plus all the other internal stuff, plus getting the heads at the right port its pricey. just boost it and youll be fine. you dont even have to stroke or do anything with the 2v, you can still make the power, with strong internals and lots of boost
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old September 9th, 2007, 09:24 PM   #32
2006 Mustang GT
+1
Cheaper, less work and easier than strokeing or boreing it.
Old September 9th, 2007, 09:35 PM   #33
now what about stroking the 4v? without boring it - just a line hone ( i think thats what my builder said i would have to do) would it be better to stroke it (make more power with less boost)?
Old September 9th, 2007, 09:36 PM   #34
i mean becausei have to have it machined anyway - and the stroker kit is the same price, i still have to put it all together - isnt it more bang for the buck?
Old September 9th, 2007, 10:22 PM   #35
i wouldnt do it, no need on the 4v, just do the line hone and be done with it
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old September 9th, 2007, 10:45 PM   #36
i mean - is there a disadavantage doing that? I guess if the motor is worn though it might have to be bored to stroke it right?
also what about the 4v heads, new valves and springs?
Old September 10th, 2007, 08:35 AM   #37
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
If you need the rotating assembly and the stroker kit is the same price, why wouldn't you get it? According to the comments here, it will give more low end torque and power. If you need the parts anyway that torque and power is free. The other mods come at an additional cost.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old September 10th, 2007, 01:11 PM   #38
no need with the 4v, it has the flow potential to make up fro any stroke, and modulars allready have enough stroke. if your doing big cams, spirngs and the rest of the valve train are a must. your gonna need to do a line hone on all the bores before hand anyways but no reason to go beyond that extra couple thousandths. the stroker setup is nice and does give lower end torque but its not gonna be as dependable becuase the modular motor allready have enough stroke. no need for more.
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Threads Similar to: Rotating assy
Rotating Assembly? NMR-2vGT 96-98 36 January 31st, 2008 05:15 PM
Rotating Assembly J Mac0123 99-04 13 October 3rd, 2007 01:07 PM
Rotating Assembly on an 03' GT hubba076 99-04 1 May 16th, 2007 02:34 AM
Fuel Pump Assy. Compatability Question menedu 99-04 2 October 18th, 2006 10:49 AM
