Rotating assy
Old September 9th, 2007, 02:48 PM   #1
shamntgmry is on a distinguished road
Rotating assy
Got a question. I am looking a a forged rotating assembly for my 03 Gt. With the stock setup the motor redlines at 5700 rpms ok. Well reading about several name brands of pistons, rods, and cranks. How do you know what rpm they are safe to? None of those kits really say much except good to 600 and 700 and 1000 HP. Does any one know about winding this oll 4.6 up?
Old September 9th, 2007, 03:09 PM   #2
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
it redlines at 5700 cause it stops making power around 5500. it will rev higher, but the heads, cams, and intake wont breathe enough for it to go higher. the rotating assembly will handle more rpm's, but it depends on how much power you're putting to it.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old September 9th, 2007, 03:36 PM   #3
Proud American
MustangMatt96GT's Avatar
Wrong. The first to go on a motor that is reving high is the valve springs. If you have valve springs that are aftermarket. I would say its safe to rev it up to about 6500. And as long as you dont stroke your motor, you should be safe to 7500-8000 with valvesprings, forged internals, everything [completely built motor(10-15K)]. Once I have my PI swap done up top, I will be making power above the 6500 mark, but I will be shuting her down around 6300 because I dont want to throw a rod. The rotating assembly in the motor shouldnt be pushed pasted 6500 on a daily basis. I mean sure if u have no limiter and it winds past it for a short time so be it, just as long as u dont run it up above 6500 that often. Sure you will see the motors that are stock short blocks, that are wound up to 7200, but not all will do that and I do not suggest you do that.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old September 9th, 2007, 04:10 PM   #4
Yeah see, if I built the motor with higher strength internals I would like to rev it a little bit higher, ah is 7000 RPMs out of the question safely? And yes like the other guy said if the motor stops making power at say 6000 I can fix that.
Old September 9th, 2007, 04:29 PM   #5
Proud American
well with forged internals I would say7500 is easily safe, aslong as you dont go with a stroked set up. And just by switching cams you can change wehre it makes power!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 9th, 2007, 05:52 PM   #6
ItalianBullitt754's Avatar
ItalianBullitt754 is on a distinguished road
Send a message via Yahoo to ItalianBullitt754
Hell if you just had you engine balanced, rods flash ground and shotpeened, ringed it with some TotalSeal Sealed power rings, put in a 7qt (Canton or Moroso) oil pan along with windage tray and upgraded your oil pump, valve springs, heads and cams along with a better breathing intake manifold(Bullitt or trick flow) you should be able to rev to 7k or even 7500rpms safely and make decent power too. I would suggest a better water pump and under drive pullies too. Might want to uncork the exhaust too with some mid or long tube headersm x-pipe and catback. Just add alittle boost for more fun now that the rods are stronger.
01' DHG Bullitt Mustang
89' and 93' SHO's: Faster then you think
94' STS Cadillac: Ghetto cruiser
Old September 9th, 2007, 05:58 PM   #7
Thats why I love SHO's They can do around 8,000 rpms stock if you chip it. I used to run mine up there all the time.
Old September 9th, 2007, 05:58 PM   #8
Badasstang281's Avatar
Badasstang281 is on a distinguished road
Send a message via MSN to Badasstang281
or just buy a formula 1 car Engine you will be good for 18,000 rpm's
BBK cai P&P 75mmtb P&P plenum BASSANI exhaust MAC x-pipe NO CAT"S ACCEL direct fire coils NGK iridium spark plugs lX7 Eibach pro-kit springs
Old September 9th, 2007, 06:08 PM   #9
Hell I would if it didn't have to be rebuilt after every certain # of hours of use oh and if they didn't cost $70k+.
Old September 9th, 2007, 06:22 PM   #10
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Why does stroking your motor make a difference?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old September 9th, 2007, 06:33 PM   #11
Stroking puts more stress on your motor. Rods in particular and the crank. Nothing like throwing a rod or shearing a rod at 7k+rpms. Strokers don't usually like high RPMs. Stroking usually boosts low end torque.
Old September 9th, 2007, 07:11 PM   #12
Proud American
now if you bore it, you can wind it up high, just not when extending the stroke!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 9th, 2007, 07:15 PM   #13
Hell Yeah! A bored out balanced high revving excellent breathing cammed GT. That would rock!
Old September 9th, 2007, 08:03 PM   #14
camarosRgay is on a distinguished road
well with good studs, the bored stroker ought to be able to turn the same rpms, wouldnt you think?
Old September 9th, 2007, 08:20 PM   #15
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
too bed that runs about an extra 5k on top of sticker
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old September 9th, 2007, 08:24 PM   #16
Proud American
no, its just not possible!
And a 3.700 bore stock 4.6 stroke, with PI heads and cams can make 400 plus N/A RWHP.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old September 9th, 2007, 08:52 PM   #17
dut ho wwill that hld up strenght wise to boosted conditions - with a 600-800 rwhp potential?
Old September 9th, 2007, 08:54 PM   #18
?????? Huh? What world is that from? Is that 1000 feet below sea level? Is that on Nitrous?
Old September 9th, 2007, 08:55 PM   #19
Drgnracin72's Avatar
the stroker can and will turn rpms faster than that....... as long as you use quality parts buttoning it up and have good parts in it. mine is good to 8000 but stop making power at 6500 so it shifts at around 7000
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old September 9th, 2007, 08:56 PM   #20
also its going to take some monstrous heads and cams to turn the rpm its gonna take to make that kind of power all motor. ive seen them but its an expensive engine and not gonna be real streetable becasue of the high rpms that it will make pwoer at
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Threads Similar to: Rotating assy
Rotating Assembly? NMR-2vGT 96-98 36 January 31st, 2008 06:15 PM
Rotating Assembly J Mac0123 99-04 13 October 3rd, 2007 02:07 PM
Rotating Assembly on an 03' GT hubba076 99-04 1 May 16th, 2007 03:34 AM
Fuel Pump Assy. Compatability Question menedu 99-04 2 October 18th, 2006 11:49 AM
