Cams and heads install
Old September 10th, 2007, 05:43 AM   #1
DrHolliday is on a distinguished road
Just thought you guys would like to know that me and amphibrecon are almost done with his cam and head install. We put on the Patriot Stage 2 heads and the comp 270 cams. While we where in there we put on some bbk shorties.
Had a few snags in the install, one of the bolts that holds the cams down on the new heads stripped out the whole when we pulled it out. We just drilled out the hole and tapped it with bigger threads. The only other problem with the install was the retarded dip stick tube. We had to pull the header back off the motor to get it to go in then bolt the header back on.
Also, to further add to the never use RPM outlet trend. He bough some of his parts from them, half the stuff hasn't showed up yet and then sent the wrong intake manifold gaskets. Had it not been for the gaskets we would have had it running tonight.
On a different note, I finally got my KB pulled off my wrecked car. Everything looks good on it the only damaged piece was the intercooler and the mounting bracket for the intercooler reservoir, both are fixable!
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old September 10th, 2007, 06:03 AM   #2
ZKid's Avatar
2002 GT
ZKid is on a distinguished road
AWWW man buddy i get caught up for a few months and your car gets smashed, what happened? Mine still isnt out to the island yet. It has probably been one of the bigest headaches i have had to deal with.
Amp got some new goodies huh? Damn... now i know he will be beating me. Gotta start maxing out that card.
Good to hear that everything is fixable though
02 GT... JLT Cold Air/ Diablo Tune/ MAC Catback Exhaust/ FRPP 3.73's/ Steeda Triax/ Eibach Pro Kit... A work in progress.
Old September 10th, 2007, 11:20 AM   #3
neckbonekat's Avatar
2005 Cadillac STS V8
Well , everything, but the car. LOL I hope you guy have been taking pic or doing small video installments. You can leave out all the cursing I'm sure you did at times. LOL
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old September 13th, 2007, 03:41 PM   #4
We took alot of pictures throughout the install. The hardest parts where putting on the headers and the BBK valve covers.
I'm sure amp will post up soon with the pics and everything, its getting tuned on monday. You guys should hear it, sounds mean as hell when its sitting there idling.
Mustangless atm
Old September 13th, 2007, 06:27 PM   #5
Proud American
MustangMatt96GT's Avatar
I want pics!! Please dont tell me u used adjustable cam gears though!!!!!!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Threads Similar to: Cams and heads install
New cams and heads GT/CS 2005 - 2010 2 August 16th, 2007 12:25 AM
Getting Cams and heads DrHolliday 99-04 4 July 2nd, 2007 08:28 PM
Heads and Cams help please! 00silvergt 99-04 4 June 10th, 2006 09:56 PM
PI Cams On Non PI Heads reeds98gt 96-98 13 April 25th, 2006 09:15 PM
