leaking...again
Old September 10th, 2007, 10:59 PM   #1
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
leaking...again
ok ive heard that an h-pipe leaking is a prob that happens alot, but im tired of crawling under my car to find a leak. this time its the freaking driver side where it bolts to the header (u know the side that satin designed to be impossiable to get to) i used baby powder and my wife giving it a little gas to find it. well one of the studs is jacked up. i know that a chiltons manual is ur friend in this situation but any advice, experiance in this matter. how hard is it to back the studs out. now im planning on getting shortys before to long but still saving my ends to get it. is there an easy fix until then, can it cause damage. its driving me crazy, when i down shift u can hear the gasket rattle and i can feel a little drop in power....
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
Old September 11th, 2007, 08:38 AM   #2
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
its not going to cause any damage , its going to just be annoying until you get it fixed and like you said , a loss of power. im not too sure on how to fix it but im sure somebody here does
Old September 11th, 2007, 08:46 AM   #3
stanginit's Avatar
stanginit is on a distinguished road
You will need a stud extracter
'99 GT, BBK Long Tubes, BBK X-Pipe, Flowmaster Delta 40's Catback, Accufab 70mm TB, C&L Inlet Pipe and MAF, 3.73's, Eibach Pro-Kit, Tokico Ilumina 5-way Ajustables, Granetelli Upper and Lower Control Arms, 18" Chrome Bullets
Old September 11th, 2007, 10:50 AM   #4
02StangGToWNEr's Avatar
2006 Mustang GT
02StangGToWNEr is on a distinguished road
Re: leaking...again
Stock or Aftermarket H-pipe??? Because I never heard this about any mid-pipes, unless they were improperly installed, or not tightened enough.
Old September 11th, 2007, 12:33 PM   #5
Rebel Of The Sacred Heart
travis_afx's Avatar
'02 GT
travis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of light
yeah i had this problem with my mac exhaust with an off-road x-pipe........it turned out that whoever put it in decideded to pretty much finger tight half of the bolts
Old September 11th, 2007, 01:30 PM   #6
2006 Mustang GT
Thats why then, you shoud always use a wrench, and tighten them as tight as you can.
Old September 11th, 2007, 03:09 PM   #7
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
I had to use a dounut type gasket on mine, no problems since and Ive it it off and on probably 5 times.
Bolt on list in Garage..
Old September 11th, 2007, 08:56 PM   #8
ujslost's Avatar
I agree here, but sometimes that wont even work after they get rusty. Try to get a tap and die set and fix it and put new nuts on there. If you can get the stud out use a nut and bolt to fix it.
Old September 12th, 2007, 03:13 AM   #9
mpboy's Avatar
2002 GT
99.99@999.9
Re: leaking...again
yea HMUSN was helping me out when i put it on and he said u got to crawl under there a couple of times to make sure its sitting flush after tightning it up
Threads Similar to: leaking...again
Top leaking jblood37 99-04 8 September 19th, 2007 01:00 AM
my car is leaking? brianm 99-04 17 September 13th, 2007 11:49 PM
Leaking vnmous 99-04 4 August 13th, 2007 12:49 PM
Oil leaking in car nasty92LX 5.0 Mustangs 3 August 12th, 2007 04:02 AM
Leaking Gear Oil? Stan27 General Tech 8 July 19th, 2006 11:38 PM
