header install
Old September 11th, 2007, 12:33 PM   #1
nutterbutter's Avatar
2002 GT
88mph @ 1.21 jigawatts
nutterbutter is on a distinguished road
header install
ive had bbk shorty headers sitting in my garage for like 6 months now, already have slp's and o/r h pipe which sound badass by the way. has anyone done the install before that can give me any pointers? i know the motor has to come off the k member but what else? i refuse to pay 8hrs of labor for something that seems so simple, just time consuming. if anyone has any tips let me know, i should be doing the swap next wednesday. just ordered some black deep dish bullit 18x10 and 18x9's w/ the chrome lip and 4.10's. im thinking my car should be pretty fast after the header install and gears. i have the diablosport tuner already as well for the gear install. basically i will have slp catback, mac o/r hpipe, tuner, and 4.10's on 18'' rims. i plan on taking it to the track when i get all this shit done. anyone have track times from a similar setup? id like to compare my results.
Old September 11th, 2007, 01:29 PM   #2
02StangGToWNEr's Avatar
2006 Mustang GT
02StangGToWNEr is on a distinguished road
Headers are a big pain in the ass to install. If your gonna attempt it, have a friend with some knowledge of installing headers, help you.
Old September 11th, 2007, 01:49 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
Re: header install
ive been working on cars for years, they are the worse set of headers i have ever done!
Old September 11th, 2007, 02:09 PM   #4
2006 Mustang GT
Re: header install
Hey if he wants to try it, and fucks them or his car up, then so be it. Atleast we warned him, that help or pros are gonna be the best bet.
Old September 11th, 2007, 02:16 PM   #5
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
if you have a pretty good knowledge base around cars, then you will be able to do it. it is a grueling task and very time consuming!
Old September 11th, 2007, 03:39 PM   #6
stanginit's Avatar
stanginit is on a distinguished road
Its pretty simple if you have the right tools. If you have access to a lift, it will make your life easier. You are going to also need some sort of engine holder when you drop the K-member. Other than that just a big variety of sockets, swivels, a stud exracter (dont remember the size)and a couple long extensions. Basically secure the engine holder to one nut on the passenger and one on the drivers side of the engine, lift the car, remove tires,disconnect the rest of the exhaust, remove the egr valve, disconnect abs sensor and brake lines, there are like 2 or 3 hoses to disconnect from the front, disconnect the steering shaft, and you can remove the 10 bolts on the K-member ( make sure you have a stand of some kind to hold the member or remove 8 bolts lower the car to the floor remove the other 2 and leave it on the floor) Now you can take the headers off. Remove the studs with the extracter. Your going to have to pull the dip stick tube out. Its in there good so you are going to have to pry it out. if you use the supplied bolts pay attention the the shorter ones These are the pain in the @zz ones. Thereis one on the driver side you are going to have to start before you put the header up. This was the hardest part holding them in place to start the bolts. Your going to have to bend the dip stick tube a little to route it through the headers. Now you can put it all back together. Notes: When you are bolting the K-member back up make sure to connect the steering shaft back up. On the drivers side it would probably make it a lot easier to hook the egr back up before you bolt the header on or just remove it up top at the throttle body. If you dont have a tuner to turn off the O2 sensors you will need MIL eliminator and extensions or it will throw the CEL. Hope this helps and if i forgot anything please let him know.
'99 GT, BBK Long Tubes, BBK X-Pipe, Flowmaster Delta 40's Catback, Accufab 70mm TB, C&L Inlet Pipe and MAF, 3.73's, Eibach Pro-Kit, Tokico Ilumina 5-way Ajustables, Granetelli Upper and Lower Control Arms, 18" Chrome Bullets
Old September 11th, 2007, 03:53 PM   #7
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
go ahead and orde a set of felpro gaskets to use for the headers...
like someone else stated... get someone to help you...
think ahead.... my transmission stayed hot 6 of the 9 hours of installation... which sucks in tight spots
Old September 11th, 2007, 04:26 PM   #8
ZKid's Avatar
2002 GT
ZKid is on a distinguished road
He pretty much put everything out there. Have a buddy that is pretty good with cars, to be there with you if your not. If you have the general knowledge down you should be fine. The biggest thing i can say is just have alot of patience!!! Things are not going to come off smooth and it wont just bolt back up nicely, so take your time and be patient. Then let us know how it went.
02 GT... JLT Cold Air/ Diablo Tune/ MAC Catback Exhaust/ FRPP 3.73's/ Steeda Triax/ Eibach Pro Kit... A work in progress.
Old September 11th, 2007, 07:11 PM   #9
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
Re: header install
That is a very true statement, and get stage 8 header bolts. I have built my car so I can slip the motor in with them on!
Old September 11th, 2007, 09:12 PM   #10
2002 GT
i have 2 friends that are going to help me. one is a mechanic, and a few cases of beer does not compare to almost 800 bucks. but i just wanted to know what was involved so i kinda know what is going to be involved. ill pick up some stage 8 header bolts. one of the shops that quoted me had that in the quote. so the gaskets from bbk suck or what? do i need new ones? we have an engine hoist and air tools ready. i have some cash aside in case we fuck something up and my sister is in germany so i have her car to drive just in case. thanks for the how-to write up it should help alot thats what i was looking for.
02' GT
BBK Headers, Bassani x pipe, SLP LM1, Diablo sport predator w/ custom tune, 4.10's, 18x9 &18x10.5, Nitto 555's, subframe connectors, Eibach Pro-kit, Grill delete, 9k HID kit.
Old September 11th, 2007, 09:21 PM   #11
13.00 @ 105
pretty much felpro's are aluminum and reusable..... and i've never heard of them leaking if used correctly
Old September 11th, 2007, 10:13 PM   #12
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i got percy's header gaskets for mine. they are reusable and they didnt leak on mine.
Old September 11th, 2007, 10:26 PM   #13
Assistant to the Manager
Smoothgrandmama's Avatar
12 GT
8.46@88 1/8
Smoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really nice
iTrader: 6 reviews
Send a message via AIM to Smoothgrandmama Send a message via Yahoo to Smoothgrandmama
800 hundred bucks? Try 450
Join The MM Facebook:
Modded Mustangs Facebook
Vote For Modded Mustangs Ride of the Month
Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng
Old September 11th, 2007, 10:44 PM   #14
neckbonekat's Avatar
2005 Cadillac STS V8
The beer is still cheaper.
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old September 11th, 2007, 10:49 PM   #15
13.00 @ 105
dammit...i meant percy's.... i was thinkin head gaskets all along
my mistake... been a LONNNG day
Old September 11th, 2007, 11:06 PM   #16
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i agree, it has been a long day
Old September 12th, 2007, 07:14 AM   #17
WAR-PARTY's Avatar
2001 YUGO GT
Did you say beer, I'm on D way!!!!
Old September 12th, 2007, 10:44 AM   #18
2006 Mustang GT
+1
Hell it would still be cheaper to have his sister ship him the beer from Germany.
Old September 22nd, 2007, 07:58 PM   #19
2002 GT
i got everything off and then realized that i had to retap the heads cause the stage 8 bolts are a little larger in diameter, but i couldnt reach it without pulling the motor out. so disconnected the drive shaft and whatnot to pull the motor up and retapped everything. got the headers on and there is 1 friggin bolt that wont go in, i think its partially cross threaded cause it starts going in crooked. so gotta take it all back off again and do it over cause i dont wanna blow the gasket out after all this work. anyways i should be finishing on wednesday when i have some more time. this swap is rediculous by the way
Old September 22nd, 2007, 10:15 PM   #20
Can't say you weren't warned. LOL
ITEMS FOR SALE!
Threads Similar to: header install
Header Install zerofx150 99-04 24 October 9th, 2007 10:45 AM
Header and X-pipe install AndyG47 V6 Mustangs 40 August 23rd, 2007 01:32 PM
header install superman5.0 5.0 Mustangs 15 June 30th, 2007 11:08 PM
header install dumps 2005 - 2010 8 May 18th, 2007 01:25 AM
Header install help lecherp 99-04 1 April 4th, 2007 03:18 AM
