Fuel Injectors (noob questions)
Old September 12th, 2007, 01:54 AM   #1
Reset is on a distinguished road
Send a message via AIM to Reset
I was talking to one of my friends today and he said a good upgrade for my car would be fuel injectors.
I have a bunch of questions:
What exactly do they do? Just pump more gas in, so your car in running rich?
How much am i looking at spending on them?
What kinds are there, which one do i want (30lb?) and where can i get them?
How much MPG can i expect to lose?
How much is reasonable for an install?
Originally Posted by 96GTRagTop
MSO is a 12 year old asian, redfire is a 35 year old pedaphile, and HMUSN, well he's just a program the mods installed on the site to keep the peace
Old September 12th, 2007, 02:00 AM   #2
02StangGToWNEr's Avatar
2006 Mustang GT
02StangGToWNEr is on a distinguished road
Re: Fuel Injectors (noob questions)
First off, whats done to your car as far as mods go?? Because unless you got more than the basic bolt-ons, then you won't need to upgrade your injectors yet. Fuel injectors are there to feed your car the proper amount of fuel it needs, so it can run properly.
Old September 12th, 2007, 02:06 AM   #3
That was a question i forgot to post.. so i need other mods before i can put on better injectors? My car is stock.. I'll probably get a CAI soon.. so getting injectors would be useless then?
Old September 12th, 2007, 02:08 AM   #4
neckbonekat's Avatar
2005 Cadillac STS V8
If you are still N/A then you don't need injectors. It's not until you ad a power adder or nitrous that you'll need those. Maybe with a really aggressive cam.
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old September 12th, 2007, 02:12 AM   #5
2006 Mustang GT
Yes. You won't need them for a looooooong while yet.
Old September 12th, 2007, 02:23 AM   #6
silvergtstang99's Avatar
2004 Mach One
silvergtstang99 is on a distinguished road
I thought injectors are only upgraded for when you need bigger ones due to Supercharger or something.
They don't add horsepower or anything, right?
Originally Posted by zinc02GT View Post
...an X pipe and Flowmaster 40s sounds like pure sex to me. Ive heard it in person many many times and everytime I have to clean myself up...
RIP 2v
2004 4v Mach One
Old September 12th, 2007, 02:28 AM   #7
2006 Mustang GT
Correct. Although they can be bought if you get Head & Cam work done. And they don't add any HP. They just feed larger amounts of fuel where needed, and unless Supercharged, Turboed, or any other major engine works been done, then they don't need to be upgraded.
Old September 12th, 2007, 02:29 AM   #8
so the only mods i can really get that this point (short of FI and nitro) is Intake, headers, exhaust.. maybe some cams.. and thats it?
Old September 12th, 2007, 02:29 AM   #9
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
they dont add power, they support power. stock 19lb injectors are good for 320-330 rwhp. after that you will need to invest into a set. the car will need to be tuned for them. they wont use any more gas under normal load, and nothing will change as far as how the motor runs as long as the cars is tuned. if running a wet shot of nitrous, injectors will not be affected at all as long as the correct jets are installed. if you go with a dry shot, then an injector change might be needed.
Old September 12th, 2007, 08:11 AM   #10
Gears
CAI
Shifter
tuner
rear control arms
headers
mid pipe
exhaust
UDPs
TB
Plenum
ITEMS FOR SALE!
Old September 12th, 2007, 11:30 PM   #11
Originally Posted by neckbonekat
rear control arms
UDPs
TB
Plenum
What are those things?
PS- i heard getting a tune can mess up your engine or something like that.
Old September 12th, 2007, 11:44 PM   #12
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
UDP's = under drive pulleys. these will replace your water pump, alternator, and crankshaft pulleys. they do basically what they say, "under drive" your accessories. they will help to reduce parasitic drag off your engine that robs power. pulleys are good for maybe 4 horses and 1-2 miles per gallon increase.
rear control arms are what connect your rear axle to the frame. upgraded ones help get traction to the ground.
Plenum and TB (throttle body) are your basic upper intake. a bigger throttle body will let more air in and a better plenum will flow air more freely into the engine. i believe an aftermarket tb/plenum combo gains around 15 horsepower.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old September 13th, 2007, 12:02 AM   #13
2006 Mustang GT
rear control arms
UDPs
TB
Plenum
A proper tune will help your engine. Who told you a tune is bad for your engine?? I never heard that before, so i'm just curious.
Old September 13th, 2007, 12:18 AM   #14
rear control arms
UDPs
TB
Plenum
One of my friends at school.. i think he is very mislead in many aspects of cars because he has told me things before that i found out were not what he thought they were.
Thanks a ton man. How much would most of those things run me and how much for installs?
Old September 13th, 2007, 12:45 AM   #15
2006 Mustang GT
rear control arms
UDPs
TB
Plenum
You should be able to install all of those parts yourself, and if you need help, grab a friend or ask us if you get stumped.
Steeda UDP's will be $189.95:
http://www.americanmuscle.com/st4unpum20gt.html
Accufab TB & Plenum will be $399.99:
http://www.americanmuscle.com/ac42v75thbop.html
Steeda Lower Rear Control Arms will be $298.95:
http://www.americanmuscle.com/stallorecoar.html
Steeda Rear Upper Control Arms will be $229.95:
http://www.americanmuscle.com/staluprecoar.html
Those are just examples though, you can buy whatever brands you want from where ever you want. The ones I listed are some of the best of each brand though imo. Enjoy.
Old September 13th, 2007, 01:26 PM   #16
Steve O's Avatar
Steve O is on a distinguished road
Send a message via MSN to Steve O
hey will the accufab tb and plenum combo work with a jlt cai? i think it will but im not sure though i just wanna be sure first
Old September 13th, 2007, 02:05 PM   #17
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
yes, it will work and thats a good combination.
Steve 0 and Reset: you are both eligable for a 6% discount from americanmuscle.com, so if i were you i'd buy from them. free shipping too!
Old September 13th, 2007, 02:11 PM   #18
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
yeah dude you wont need injectors for a longgg time...save that money and buy something that will actually do something
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Old September 13th, 2007, 05:57 PM   #19
2006 Mustang GT
Yes! And they look badass matched together.
Old September 13th, 2007, 10:21 PM   #20
Just DO NOT buy from RPMOutlet.com. They seem to be major rip off artists.
ITEMS FOR SALE!
Threads Similar to: Fuel Injectors (noob questions)
2 Noob questions auburntiger7231 99-04 9 August 23rd, 2007 09:34 PM
Fuel Injectors/fuel pressure 00silvergt 99-04 4 August 2nd, 2007 09:54 AM
Noob has Cobra questions.. lol whtpny 99-04 32 March 27th, 2007 12:29 AM
Total Fox Body Noob - Have Some Questions (Performance) r00st 5.0 Mustangs 8 October 6th, 2006 04:24 PM
Mustang Or Something Else? nOOb Questions wantstang Modular Mustangs 9 October 6th, 2006 12:09 AM
