![]() iTrader: 1 reviews
hid help
i posted this in the electronic forum but id kind of like to get this solved asap,
So I bought an hid kit a long time ago, it was some asian company, so the passenger side started to flicker about a month after i got it, and then it eventually would either a) not turn on or b) turn on and off, until it just stopped working, checked the connections and the power stopped at the ballast so im guessing it was a blown ballast, anyways, i bought a new one from american muscle and its doing the exact same thing except on the drivers side now, i emailed them and all they told me were to check the connections, which i did several times over. anyone have this problem?
2002 GT
hmmmm.... did you buy a whole new kit from Americanmuscle or did you just by a new ballast? That is really strange that it switched lights. sounds like its shorting off somewere.... are your connections covered (no wire exposed)?
02 GT... JLT Cold Air/ Diablo Tune/ MAC Catback Exhaust/ FRPP 3.73's/ Steeda Triax/ Eibach Pro Kit... A work in progress. |
yes the connections are covered, the battery acid ate away at the rubber around one of the cords becuase of the lack of room our cars give us, but i moved it around and it didnt short out anywhere.
check your ground, might be a bad ground
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
mine did the same thing and i could never figure it out , i put another kit on it...
#6 | |
a bad ground can do funny things |
check the ground or check where it goes into your original headlight system
i just attached it to the ground right behind the drivers light, where the battery goes to.
try grounding it to the batt, and see how that goes
i tried that and it still doesnt work, it probably already blew. wont turn on at all now. fucking pos
#11 | |
![]() 2004 GT Boosted by Vortech |
Yeah, I hope their return policy is good.
