engine misses throughout driving speed range - Page 2
Old September 18th, 2007, 01:16 PM   #21
af00stang's Avatar
13.6@100.38mph,(before tune)@3300ft elevation
af00stang is on a distinguished road
heres the pick of the coil and the bolt that holds it down.its right under the fuel rail
Old September 18th, 2007, 01:25 PM   #22
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
what engine do you have and what year?
Old September 18th, 2007, 01:29 PM   #23
af00stang's Avatar
2000 gt 4.6
Old September 18th, 2007, 01:40 PM   #24
Juggalo_X's Avatar
14+@Slow
r u sure u dont go coil on plug (COP) i thought 1999 and later had it.
Old September 18th, 2007, 01:45 PM   #25
Juggalo_X's Avatar
14+@Slow
and if ur not COP then i see absolutly no coil pack in that pic.
Old September 18th, 2007, 01:46 PM   #26
af00stang's Avatar
It is but i cant get the coil off the plug.
Mac LT'S,BBK CAI,BBK Throttle body.trick flow plenum,1inch throttlebody and plenum spacers 75mm,95mm maf,underdrive pulleys,4.10 gears,King cobra clutch,t56 transmission,pro 5.0 short shifter,aluminum cobra driveshaft
Old September 18th, 2007, 01:48 PM   #27
Juggalo_X's Avatar
14+@Slow
ok well do you have a multimeter? you can test it right on the plug rather then removing it but i HIGHLY suggest you don't grind that off the bolt that connects the coil on plug is stripped and stuck into the metal its supposed to fasten to it would just continue to be stuck if u ground it off.
Old September 18th, 2007, 01:56 PM   #28
af00stang's Avatar
on the left side of the pic right under the fuel rail the coil pack is right there it says motorcraft on it
Old September 18th, 2007, 02:00 PM   #29
Juggalo_X's Avatar
14+@Slow
ok yah i see it. yah dont grind that nut off or u will be fucked to get the rest of it out. test that coil right on the car so if u dont got to remove it then u dont have to. unless you getting after market COP pull the wire off of it and put a ohm meter on it if the coil is good it will read a value of .55 ohms for primary resistance and secondary should be 5.5k ohms anything higher or lower and the coil is bad.
Old September 18th, 2007, 02:02 PM   #30
af00stang's Avatar
gtg go to work.will get on later.thanks
Old September 20th, 2007, 12:06 PM   #31
af00stang's Avatar
its the plug thats fucked.once the top of the bolt head is off, the coil slides right off.bolt just goes through the hole to hold it down.its not threaded to it.
Old September 20th, 2007, 12:37 PM   #32
Juggalo_X's Avatar
14+@Slow
so you got it out?
Old September 20th, 2007, 12:44 PM   #33
af00stang's Avatar
im moving on base tomorrow.once i get in my house im gonna work on it.i just havent decided which path to go as far as resecuring it after.
Old September 20th, 2007, 12:45 PM   #34
Juggalo_X's Avatar
14+@Slow
well once you removed the COP what did u find? or you havnt yet.
Old September 20th, 2007, 12:52 PM   #35
af00stang's Avatar
i havent yet but when i changed the other 7 they were all fucked.i put it off until i could find the time.nut now its starting to miss a lil bit.im going to the track in a month and i need to get it done
Old September 20th, 2007, 01:01 PM   #36
Juggalo_X's Avatar
14+@Slow
so the plugs are fucked or the COP?
Old September 20th, 2007, 01:02 PM   #37
af00stang's Avatar
my friend has a 97 trans am with about 3grand in it.we are neck and neck on the steet up to about 110 thats when his 6 speed kicks my ass.so my cars gotta be on point.
Old September 20th, 2007, 01:03 PM   #38
af00stang's Avatar
the plugs were.i bought bosch plat 4 this time
Old September 20th, 2007, 01:39 PM   #39
Juggalo_X's Avatar
14+@Slow
Those are hit or miss in fords im running them right now and they give me a lope at idle on ocassion... they were great for the first 5000k tho
Threads Similar to: engine misses throughout driving speed range
intake swap, now engine misses Ken Overton 96-98 19 October 17th, 2007 02:45 PM
Engine Lagging After Stop-Go Driving OcOnnor220 99-04 7 October 7th, 2007 07:29 PM
02 MUSTANG GT ENGINE STOPPED AT HIGH SPEED ozbusurfer 99-04 8 September 30th, 2007 12:48 AM
need tips on what engine to put in my 95 mustang 5 speed no 1stMustangCobra95 5.0 Mustangs 7 October 17th, 2006 04:54 PM
Engine Dies While Driving Mystic Mama 96-98 7 May 6th, 2006 07:55 PM
